rayroni
posted on 16/6/04 at 11:51 AM |
Is it a Crossflow Starter Motor?
I have a starter motor which I have been told came off the crossflow/4 speed 'box I intend to fit.
It appears to be an inertia type but it only has a two bolt mount, whereas the 'box has three holes.
I wish to grind of the third hole/lug due to a clearance issue.
How can I tell that the starter I have is correct for engine/gearbox prior to fitting it all in car and trying it? Are some crossflow starters two
hole mounts?
Tar.
Lars
posted on 16/6/04 at 12:46 PM |
my starter has 3 holes, but i'm also thinking about grinding one of for clearance.
zilspeed
posted on 16/6/04 at 12:48 PM |
My xflow has an inertia starter - three bolt.
Cpuldn't honestly say if there is a 2 bolt inertia. I believe there is a 3 bolt pre engaged version.
For what it's worth, my new / exchange one cost me 20 quid + vat at LSUK last week.
Mk-Ninja
posted on 16/6/04 at 01:49 PM |
Why not bolt it to the engine and try it, all you need is a battery and a pair of jump leads.
I'm sure I've got one, just don't know where I've put it
theconrodkid
posted on 16/6/04 at 02:07 PM |
afaik al pre x flow.s were 2 bolt,they kept falling out and were modded to be 3 bolt,so better to stick to the right 3 bolt item
who cares who wins
pass the pork pies
posted on 16/6/04 at 06:22 PM |
Not all Escorts had 3 bolt starters BUT I can confirm the 2 bolts jam and chew ring gear .
