chrisg
posted on 29/8/02 at 06:56 PM |
Bearing
Hello chaps,
How does one change the pilot bearing (the one that the end of the gearbox shaft fits into the crank),on a pinto?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
locodude
posted on 29/8/02 at 07:05 PM |
v.small cold chisel and wear safety glasses! I think you'll have to bray it out.
Chris PTM
posted on 29/8/02 at 07:20 PM |
In order of preference:
Slide hammer with a hook end (you might have to make a small-enough hook);
Brute force - see above...
theconrodkid
posted on 29/8/02 at 07:47 PM |
I use a die grinder,but then i,m a southerner
Alan B
posted on 29/8/02 at 08:01 PM |
What about the old shaft and grease trick?
You know, where you fill the hole with grease and then hammer a close fitting shaft into the hole, and hydraulics does the rest.
Metal Hippy™
posted on 29/8/02 at 08:54 PM |
I'm sure that there's a joke in Alans reply somewhere...
President of the Non-conformist Locost Builders Club. E-mail for details...
chrisg
posted on 29/8/02 at 09:59 PM |
Thanks Chaps,
I think I'll try the grease first, although knocking seven shades out of it does have a certain attraction......
Also, New bearings, are they a main dealer part????
Chris
posted on 30/8/02 at 07:30 AM |
Semi-official answer from Peter Wallage's X-flow book (same as in the X-flow/Pinto book, before anyone says anything...)
1. Check that it needs replacing in the first place. Most times they're just gunged up and just need WD40 or petrol to get the old grease out.
2. If you're having the crank re-ground, get the engineering shop to get the bearing out while they're at it.
3. Slide hammer may work, but the hook end has to be very small and tends to get knackered.
4. Grind the bearing out with a die grinder or Dremel.
5. Chisel and FBH (Big Hammer)
Hope this helps,
