femster87
| posted on 23/11/10 at 07:08 PM |
Engine Stamping
Just after some information of engine stamping with a pre 95 engine number. Is this just a case of tracking down a dead engine block with suitable
number age and using its number. Whats Ford/IVA take on that.
Thanks in advance for the info
flak monkey
| posted on 23/11/10 at 07:10 PM |
If it looks tampered with you'll never get it registered.
Also bear in mind enough IVA inspectors read this site to know whats going on.
Sera
http://www.motosera.com
femster87
| posted on 23/11/10 at 07:12 PM |
thanks dave,
The engine does not have a number at the moment. just deciding if to buy or not
AndyW
| posted on 23/11/10 at 07:20 PM |
If the engine does not have a number, does that mean its been ground off? There is a way of bringing a ground off number back, so be very careful. If
you stamp another number over it then it will have to be a very good job not to stick out and be obvious. If the engine is for sale without a number
then it needs to be really cheap....
steve m
"Also bear in mind enough IVA inspectors read this site to know whats going on. "
If they do, and i really do doubt it, why dont we have a section for questions and answer's on the IVA related subjects.
I would imagine that most IVA test guy's want a pass and out the door approach, as it wil be less work ?
big_wasa
| posted on 23/11/10 at 07:36 PM |
Replacement engines sold by ford never had an engine number stamped. The dealer was meant to stamp the number on, on exchange.
As time is money most never bothered. It wasnt going to worry the owner.
You could stamp it on but you will never get it to look factory. If you take the wee and put a 93 number on a black top he will know. He looks at
these day in and day out for aliving.
As long as you can meet emisions I wouldn worry.
flak monkey
| posted on 23/11/10 at 07:40 PM |
We do, its called SVA/Legal
They have been known to look on this site, as well as others, before now.
Sera
myke pocock
| posted on 23/11/10 at 07:52 PM |
You could always be totally up front and ask your local IVA tester what to do. It would mean he is aware of it but if you cannot get an answer why not
go and get another engine. Is it an engine that wasnt made after 95. My SVA tester said that he knew that x flows (I have a 1300 in mine) were only
made up to a certain time so didnt even need to check and verify the number. Not all testers as helpful as him though. My x flow engine number looks
decidedly dodgy but is definately kosher and I actually stamped a number in a Triumph Spit engine block that had come from a training workshop. It
wasnt questioned by a DVLA inspector. (now Ive given the game away!!!!!)
femster87
| posted on 23/11/10 at 07:58 PM |
Ok thanks for the reply am gonna keep my blacktop. was considering a 1.8 silvertop that was from Ginetta. Was just trying to get by emissions
requirements cheaply
big_wasa
| posted on 23/11/10 at 08:01 PM |
You shouldnt have any problems if you use that eec-4 and a cat.
femster87
| posted on 23/11/10 at 08:15 PM |
lol, I know warren. The work on the eec-4 has been on hold for sometime now. One of those times in the year when moral is low. Would get it out when
xmas break starts. The garage is soo cold right now I dont even want to get close to the place.
big_wasa
| posted on 23/11/10 at 08:50 PM |
Yep wheel mine out sunday to bolt the seats in. It started to rain so I put it back again lol.
Its about this time every year I want to sell it and by a sporty tintop.
austin man
| posted on 23/11/10 at 09:35 PM |
the stamping on the silvertops are hard to see as some of them are a series of dots making letters and numbers located just above the starter motor on
the flange where block meets bellhousing
austin man
AdrianH
| posted on 23/11/10 at 10:19 PM |
Please bear in mind that the engine number on a silvertop may not be stamped as in letter stamps but could be a series of what I would describe as
etched dots. see this image from mine. i had to use wet and dry then a camera to see it, I previously thought there was no number?
  Zetec engine no
I blanked out the last digits so could not be used although an April 96 is not sought after
Adrian
Why do I have to make the tools to finish the job? More time then money.
