po79
| posted on 5/12/10 at 03:35 PM |
ZX7-R carb questions.
Hi guys,
Just a couple of quick questions for you.
First does anyone know the ZX carb angle I have measured mine in order for Dan to sort out a self weld kit and found it to be 25degs is this
correct?
Also how do you mount these carbs all the pictures I have seen they just look to be connected to the manifold by their silicone hoses but with no
support brakets, is this correct?
Thanks,
Po.
prawnabie
| posted on 5/12/10 at 03:46 PM |
They are supported by the airbox on bikes so you will have to make up a bracket when fitting to a car engine. Make sure you use the proper fluro
silicone hose too.
lotusmadandy
| posted on 5/12/10 at 03:49 PM |
Mine have no support brackets and are fitted with normal
silicone hose.no problems to report,after 2 years hard use.
jacko
| posted on 5/12/10 at 03:59 PM |
these are my zx9r carbs the small pip is vertical if this helps
I have made a support that goes from the middle of the carbs to a bolt on the rocker cover [ pinto engine ]
  carbs on manifold
you can just see the support in this photo
  Engine
[Edited on 5/12/10 by jacko]
po79
| posted on 5/12/10 at 04:05 PM |
Thanks guys,
So basically its down to me if I do or don't put mounting brackets on then.
With brackets me thinks.
What about the angle or the carb any one know what this should be?
I guess I could use the mounting bracket to make the final adjustments though.
Po.
nearly done
| posted on 5/12/10 at 06:37 PM |
I had my runners cut at around 22 degree`s to ensure the float bowl was horizontal.I had all sorts of issues with the mounting of the carbs to
the runners,the silicone hose kept slipping of as I tightened up the clips(even the special ones designed for silicone hose). Eventually I purchased
some ali tube of the right diameter to slip over the spigot on the carbs extending them by a inch or so,this was secured with Sikaflex 221 and bingo
plenty of purchase for the clips to tighten up to. I also have braced the carbs to the head using some Stainless bar i had laying about.
Incidently I have just swopped My 750 carbs for some off a 1000 Exup !! These are secured with the
original Yamaha carb rubbers and fit a lot better than silicone hose ever would.
Cheers,Sean.
whitestu
| posted on 5/12/10 at 09:23 PM |
From my experience the carb angle doesn't matter. Mine [ZX6R] are totally horizontal and work perfectly.
Stu
