Author: Subject: fuel regulator leak causing running problems?
chrisbeale
posted on 26/12/10 at 12:04 PM Reply With Quote
I've been having running problems for a while now mainly when accelerating. It's been very juddery and spluttery sometimes when accelerating. I went out for a short trip round the village this morning and all seemed ok, its been intermittent so nothing strange there. I have thought maybe fuel pump can't cope, veal getting into the mix, air restriction, even the timing being out? But the I noticed fuel dripping from the regulator in the engine bay. It drips during idle and with just the ignition on (fuel pump on) could this be a factor, when accelerating air is being sucked in rather than fuel coming out? I believe that its leaking from the "lid" of the regulator rather than the pipes etc. It's now back in the garage as I don't fancy driving with fuel dripping into a nice hot engine bay.
The oil catch tank is getting quite full too but can't see this being a problem unless it stops breathing all together?
Any ideas?
Thanks and merry Christmas and a happy new year.
jacko
posted on 26/12/10 at 12:22 PM Reply With Quote
What carbs are you using ?
If bike remove the fuel pump / regulator you have and fit a bike pump
Jacko
chrisbeale
posted on 26/12/10 at 12:23 PM Reply With Quote
Got 40 webbers.
big_wasa
posted on 26/12/10 at 01:13 PM Reply With Quote
Bike pump or the low presure pump webcon sell. Huco is the brand name. I had one on my webers and now use it as a lift pump for my efi.
Some people have had problems with regulators as they can strangle flow rate.
You wouldnt need one with a a huco or bike pump.
[Edited on 26/12/10 by big_wasa]
snapper
posted on 26/12/10 at 05:58 PM Reply With Quote
Fuel leaking from the regulator lid seal, could also have an air leak to the pressure compensating diaphragm.
Fix that first
Don't chase any other perceived problem until the regulator functions properly.
Simples
I eat to survive
I drink to forget
scudderfish
posted on 26/12/10 at 07:16 PM Reply With Quote
Even if it isn't the cause of your problem, fix the leak now. Loose petrol in the engine bay is never the start of a happy journey.
chrisbeale
posted on 27/12/10 at 04:57 PM Reply With Quote
Ok thanks guys I will sort out the regulator and see where that takes Me.
chrisbeale
posted on 27/12/10 at 10:36 PM Reply With Quote
Ok am going to remove it to check it out, how much fuel is gonna go every where when I do this and is this as simple job as I anticipate?
scudderfish
posted on 28/12/10 at 10:44 AM Reply With Quote
Provided the pump isn't running, there won't be that much fuel to escape. Whenever I've done it, I've just stuffed a load of kitchen roll around it and in any nearby places that it's likely to pool.
