zilspeed
| posted on 27/6/04 at 08:45 AM |
Zetec Turbo
Just found a link to a site I hadn't seen before.This company, is currently doing zetec
turbo installations. Most interestingly, you will see that the car involved and shown on the pics is a westfield.
Most interestingly, if you look at the shots of the engine bay, that is a standard ford plastic inlet manifold. So - in relation to previous points
about zetecs runiing on standard injection - here's your answer.
SeaBass
| posted on 27/6/04 at 11:52 AM |
Yes it's using the standard injection inlet manifold but I doubt injectors and ECU are the same...
Add in the turbo and intercooler and keeping the stock inlet manifold with single throttle body is the best option plumbing wise...
JC
