milo_steel
posted on 29/6/04 at 09:11 AM |
What Gearbox?
Hi all,
This is my first post and I'm sure not my last, I would like to know if you can use a standard 5 speed gearbox on a 1600 Kent Xflow, and if so
any suggestions at to make/type?
Many thanks
ned
posted on 29/6/04 at 09:12 AM |
sierra 5 speed box will fit.
Ned.
beware, I've got yellow skin
milo_steel
posted on 29/6/04 at 09:14 AM |
Wow, superfast reply okley dokely Ned many thanks
Deckman001
posted on 29/6/04 at 10:01 AM |
You will need a different clutch tho, from an early 1600 sierra i have been told, then it all bolts together
Jason
theconrodkid
posted on 29/6/04 at 10:20 AM |
who told you that tosh j?
who cares who wins
pass the pork pies
Deckman001
posted on 29/6/04 at 10:46 AM |
milo_steel
posted on 2/7/04 at 07:03 AM |
So do I need a different clutch?
madforfishing
posted on 2/7/04 at 08:55 AM |
Milo, might be worth having a look at Rob Lane's site on:
www.domsat.co.uk/pages/locost.htm
Click on the LHS Hyperlink to gearboxes.
posted on 2/7/04 at 10:18 AM |
Ideally you need the complete 7.5"/192mm clutch from a 1300 Sierra 4 speed -- 2 types exist the later one for gearboxes with "seperate
bellhousing" has the correct splines for the type 9
Another way is to use the clutch driven plate for a Hilman Avenger/Talbot Sunbeam.
