josty
posted on 30/6/04 at 12:31 PM |
Differential removal sierra
Hello,
Can anyone tell me how I can remove the diff. without removing the 'sub frame' and wheels? I can lower the diff. but the drive axles are
screwing up my plan.
It seems that there isn't enough space to remove the axles.
Ciau
mangogroove
posted on 30/6/04 at 12:36 PM |
Unbolt four bolts in the back of the brake hubs and pull the shafts out L&R.....thats unless anyone got a better idea
You want it when!
theconrodkid
posted on 30/6/04 at 03:35 PM |
unless you got rear discs then there are 6 bolts to undoo
who cares who wins
pass the pork pies
josty
posted on 30/6/04 at 04:57 PM |
I also tried to pull the half shafts out of the diff. I did not succeed further than 1,5 inch. Is this possible anyway or do I have to remove the
100000 little bolts??
Josty (Holland)
theconrodkid
posted on 30/6/04 at 05:10 PM |
on drum braked cars the inner pot joints just pull out,a small circlip holds them in,on disc braked the shafts are held on with 6 bolts each side
who cares who wins
pass the pork pies
josty
posted on 30/6/04 at 05:53 PM |
It's a drum brake model.
You mean pull tem out at the dif side or the brake side?
Probably the enormous nut also has to be removed to get the axle out of the hub.
posted on 30/6/04 at 06:22 PM |
Josty,
Remove the wheels and the brake drums. Then rotate the drive shaft until the holes in the drive flange line up with the bolts that secure the hub
suspension arm.
Undo these 4 bolts, leaving the large nut in the centre in place, and the complete driveshaft will slide out of the diff and can be withdrawn through
the suspension arm.
Once both driveshafts are out you can undo the bolts that secure the diff to the subframe and lower it out of the subframe.
I don't think you will get the diff out without removing the driveshafts.
HTH
Nick
dblissett
posted on 30/6/04 at 06:25 PM |
diff
josty you have to undoo the four m13 bolts from inside the brake
you should note in the flange there is one hole you put the socket through it to get at the bolts and the whole shaft and hubs come out from the brake
end
the big nut is for the wheel bearing
ps have you drained the diff oil yet
cheers dave
josty
posted on 30/6/04 at 11:21 PM |
Oke thanks, I will try it that way.
Josty
josty
posted on 1/7/04 at 10:37 AM |
By the way, I did not drain the oil because I couldn't find a drain plug.
josty
theconrodkid
posted on 1/7/04 at 11:32 AM |
there isnt a drain plug,remove filler and empty it on yr neighbours cat
who cares who wins
pass the pork pies
josty
posted on 1/7/04 at 07:50 PM |
hehe good idea...
Josty
Chris_R
posted on 1/7/04 at 08:25 PM |
isn't the drain plug the yellow thing on the right?
![](/galpreviews/a120720-DSCN1903.JPG) ![Rescued attachment DSCN1903.JPG](/gallery/a120720-DSCN1903.JPG) Rescued attachment DSCN1903.JPG
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
theconrodkid
posted on 1/7/04 at 09:54 PM |
thats the filler/level plug
who cares who wins
pass the pork pies
Chris_R
posted on 2/7/04 at 05:54 AM |
Ah. Haven't started on that bit yet.
