Author: Subject: Can the type 9 gear box mount be mounted on a flat bar?
rich201283
posted on 20/4/11 at 08:14 PM Reply With Quote
Can the type 9 gear box mount be mounted on a flat bar of does the middle rubber piece need to be free to vibrate?
mcerd1
posted on 20/4/11 at 08:22 PM Reply With Quote
I take it you've got one of these mounts: (sierra type)
you could think about using one of these instead: (as used on early cortina's, westfield, caterham and loads of others)
http://www.caterhamparts.co.uk/product.php?id_product=85
[Edited on 20/4/2011 by mcerd1]
rich201283
posted on 20/4/11 at 08:37 PM Reply With Quote
Hi
I have got the one off caterham and mounted it on a flat bar, I have quite a bit of engine vibration, Not sure if its the gearbox mount or the landrover engine mounts
mcerd1
posted on 20/4/11 at 08:40 PM Reply With Quote
in that case I can' see that mounting it on a flat bar would make any difference as the bottom half of that type of mount is 1 bit of metal anyway... but they are quite rigid style of mount
blakep82
posted on 20/4/11 at 08:48 PM Reply With Quote
when you say vibration, is that vibration through the chassis that you feel? or is the gearstick shaking around loads?
ideally, you want to have the gearbox mount on some sort of solid box to hold it still, and the rubber in the gearbox mount that you have will dampen some vibration through the chassis giving a sort of compromise. here's what mine is like
think is, this will transmit vibration through the chassis.
on a flat bar, the bar isn't very stiff, allowing the gearbox it move up and down, and twist, meaning the gear lever will shake around instead. eventually i guess it work harden and break
[Edited on 20/4/11 by blakep82]
________________________
big-vee-twin
posted on 20/4/11 at 09:08 PM Reply With Quote
Have heard the transit engine mounts are softer rubber than the Landrover one's.
The Landrover ones have a rep for being hard.
http://www.triangleltd.com
macc man
posted on 20/4/11 at 09:48 PM Reply With Quote
I can vouch for the landrover mounts being hard. My car has loads of vibration on tickover. Once it is reved it is much less.
Another mod to do.
rich201283
posted on 21/4/11 at 06:05 AM Reply With Quote
The gearbox is mounted on a solid bar so starting to think its not that
Gonna check the exhaust tonight to make sure its not catching
Also the vibration is less when rev'd so think its probs the landrover mounts
posted on 21/4/11 at 07:11 AM Reply With Quote
Do you mean you have the middle part of the mount (that bolts to the gearbox casing) bolted up tight to the flat bar? If so then that is incorrect, the middle part must be free to move if it is to absorb vibration.
rich201283
posted on 21/4/11 at 07:32 AM Reply With Quote
the mount was bolted to the gearbox then it was put in place and bolted to the flat bar by the 2 outer bolts
[Edited on 21/4/11 by rich201283]
posted on 21/4/11 at 04:49 PM Reply With Quote
Mine is sitting on a chassis plate with a thin bit of rubber on top, one M12 I think through a hole in said plate into the gearbox.
