Author: Subject: Zetec Running Away - Help Please
edspurrier
posted on 29/4/11 at 01:35 PM Reply With Quote
Hi all
Zetec blacktop 2 litre, Weber 45, Webcon set
Running fine this morning
Now (having changed the gearbox mount) - I start the engine and it runs immediately up to the rev limiter.
Wiring is all OK.
Throttle is closed and the butterflies are closed.
No idea at all!
Supposed to be racing tomorrow - any ideas?
Ed
zilspeed
posted on 29/4/11 at 01:51 PM Reply With Quote
The butterflies may be closed, but it's getting the air from somewhere.
As Dave Walker once wrote, "you can't send air down a wire or a fuel hose."
There may be a vacum hose off somewhere ?
RichardK
posted on 29/4/11 at 02:03 PM Reply With Quote
If you have an adjusting screw, (like a bike one) make sure the sleeve of the accerlate cable is pushed fully home.
Rich
Gallery updated 11/01/2011
mookaloid
posted on 29/4/11 at 02:17 PM Reply With Quote
dodgy gearbox mount
posted on 29/4/11 at 02:21 PM Reply With Quote
Choke cable not in its correct place? (if you have a choke, that is!)
doddy
posted on 29/4/11 at 03:11 PM Reply With Quote
you may of damaged wires in side the loom is the any wiring above the gearbox if you jacked it up abit when fitting the mount
https://www.ebay.co.uk/str/4x4wheels
contaminated
posted on 29/4/11 at 07:46 PM Reply With Quote
I bet the outer part of the throttle cable is caught on its adjuster just before the carbs. Has happened to me several times.
Tiger Super Six Independent
www.southernkitcars.com
