Author: Subject: Electronic ignition - any ideas?
j3w3ll3r
posted on 7/5/11 at 01:15 PM Reply With Quote
Hi Chaps,
Thanks in advance,
Just wondering if you can tell what electronic igntion we have on our car based on the last set of pics from this - Piccies - that's if i'm looking at the right thing!
thanks in advance...
[Edited on 7/5/11 by j3w3ll3r]
www.essexhomegame.co.uk
deezee
posted on 7/5/11 at 01:44 PM Reply With Quote
It looks like your running the standard distributor ignition..... as you have a distributor sticking out your engine. The last photos look like coil amplifiers.
omega 24 v6
posted on 7/5/11 at 02:43 PM Reply With Quote
I'd agree with deezee.
posted on 7/5/11 at 04:15 PM Reply With Quote
The 20XE/C20XE has the ignition driven from the same ECU that does the fuel injection, so if you are running carbs then it's probably the system from the old 8v Cavalier engine that's been grafted on.
j3w3ll3r
posted on 10/5/11 at 01:02 PM Reply With Quote
ok - so it's not programmable, mappable and i can't do any tuning with it?
sorry chaps - just struggling to get my head round this ignition stuff.... How does this differ from say a megajolt, h&h or lumenition system ?
Many thanks in advance..
sky12042
posted on 12/5/11 at 10:18 PM Reply With Quote
Megajolt is a stand alone ecu, can be mapped, will need a trigger wheel on the front pulley, and half a day on a rolling road to set up properly.
H&H are a company that will adjust your distributer so that it advances the spark correctly for carbs.
Lumenition are a replacement for the old points system, you don't have points.
Also there is MBE who are supplied by SBD motorsports who do a ignition only ecu, can be mapped and fits better on the redtop as uses the original trigger wheel.
http://www.sbdev.co.uk/Parts%20Catalogue.htm
