Author: Subject: another diff question
markie t
posted on 16/5/11 at 08:32 PM Reply With Quote
i am currently running a 7" 3.62 open diff with lobro type shafts and have acquired a 3.14 7" diff (47cw 15p) code on diff casing is 83-BG-4025-BE, can anybody tell me what this is from as cant find any similar codes in the sticky for a sierra, also the 3.14 diff has no output flanges with it, can i use the output flanges from the 3.62 ? or does this mean that this 3.14 diff has push in shafts only and would mean changing shafts, hubs and brakes to drums ?
daniel mason
posted on 16/5/11 at 08:39 PM Reply With Quote
i think the diesel sierra had the 3.14 diff
[Edited on 16/5/11 by daniel mason]
danny keenan
posted on 16/5/11 at 08:44 PM Reply With Quote
u2u set
cheers danny
gaz05
posted on 16/5/11 at 08:58 PM Reply With Quote
Mines from a 1.8TD and it's a 3.62.
daniel mason
posted on 16/5/11 at 09:03 PM Reply With Quote
if my memory is correct i thnk a 2.3 diesel. not the 1.8td
jacko
posted on 16/5/11 at 09:13 PM Reply With Quote
no2
no2
snapper
posted on 17/5/11 at 04:22 AM Reply With Quote
You can get a diff rebuilder to fit crown wheel and pinion to the 3.62
You can fit lobros to the 3.14, not easy and needs a little fetling to stop the lobro sined shaft jamming the planet gear shaft.
You can make hybrid push fit to lobro drive shafts using the thicker diesel push in shafts and lobro CV outers
I eat to survive
I drink to forget
mcerd1
posted on 17/5/11 at 07:46 AM Reply With Quote
spot on
1.8 td = 3.62
2.3 d = 3.92
