deep blue
| posted on 13/6/11 at 10:30 PM |
splines for type 3 ford box interchangability.
I am struggling to find a front few inches of a ford propshaft or even a full propshaft local to us in goole east yorkshire.
This car is running a mk2 escort 1.3 four speed think it is a type three from memory. you tell me!.
I was thinking what other ford cars share spline sizes etc that will fit these boxes to make sourcing one nearer home a bit easier.
PS if you have anything to help us out and are reasonably local please let us know.
blakep82
| posted on 13/6/11 at 10:42 PM |
click on the gearbox links here
http://www.burtonpower.com/tuning-guides.html
for info on the different possibilities and what they were fitted to
as it sands in your request, could be anything
type 3 doesn't appear to have been fitted to escorts
edit: type 2 perhaps? apparently fitted to all mk2 escorts except rs/mexico and twin cams.
[Edited on 13/6/11 by blakep82]
________________________
deep blue
| posted on 13/6/11 at 10:53 PM |
Type 2 it is then, i was none to sure. Thank you for the info it is of great help at least i know what box i have now, that is a start.!
[Edited on 13/6/11 by deep blue]
snapper
| posted on 14/6/11 at 05:44 AM |
As far as I can tel Ford only ever used 2 input shaft diameters and splines, 7/8" by 20 splines or 1" by 23 splines.
Your early box will be 7/8" by 20 splines.
I eat to survive
I drink to forget
TimEllershaw
| posted on 14/6/11 at 06:33 AM |
Is this of any use to you ?
From Ford Type 3 gearbox and English Diff, from an old Westfield :
  Propshaft
  Prop End
  Prop end
Tim.
http://www.teenagecancertrust.org/
deep blue
| posted on 15/6/11 at 11:25 PM |
Thanks for the input it looks as thought the tailshaft splines are the same throughout the majority of Ford cars from the 100es to the sierras etc,
so almost anything will do me for the propshaft nose i require.
Thanks for the offer Tim elershaw, i am now chasing a propshaft from just a few miles away over the border in to darkest Lincolnshire, If it
fails to materialize as promised, i will be in touch pronto thank you!
I will post my progress either way.
blakep82
| posted on 15/6/11 at 11:51 PM |
erm, not quite, there's 2 different ones, a 7/8" i think it is, and a 1", guaranteed you'll have the wrong one for whatever
prop shaft you get. can you not get to the tail shaft to measure it.
i've only ever come across the 1" ones.
