LBMEFM
| posted on 16/6/11 at 08:37 PM |
Turbo charging
Reading an earlier post with suggestions for fitting turbo/supercharger, is it possible to fit one to a carb'd 898cc Blade engine and what can I
expect with regards to the cost and the amount of work required.
ReMan
| posted on 16/6/11 at 08:59 PM |
Very possible, it will be my winter project
Looking to 180+ HP probably cost under £1000 in a locost stylee.
Have a look here..
http://www.bike-turbo.com/forum/index.php
It's a bit quite but building up steadily
I Met this chap at Stoneleigh for a bit of high tech med cost with water injectin too
  w inj turbo
www.plusnine.co.uk
rgrs
| posted on 16/6/11 at 09:02 PM |
Hi Barry, might be worth a call to Ashford Motorsport, their based in poulton close, dover.
The owner has a fireblade bike that he fitted a turbo to a few years ago.
Roger
mark chandler
| posted on 16/6/11 at 10:02 PM |
Here's the expensive way:
turboblade
If you are able to make up the bits then quite cheap, mine suffered clutch slip so had to invest another £400-£500 in a lockup clutch, with HD springs
on factory plates it was marginal.
clutch came from here, I paid for the cad drawings so should be less than I paid
psycleworkz.com
It makes a huge difference to the performance..... well worth the effort, I shuddered at the cost of a decomp plate so only run low boost, 7psi but
this is worth 201bhp on the dyno
I will see you at Lydden next week so come for a spin around the track.
Regards Mark
[Edited on 17/6/11 by mark chandler]
LBMEFM
| posted on 17/6/11 at 06:42 AM |
Thanks for the replies, how are you Roger, haven't heard from you for a while and I will see you next week Mark. Barry
hiflow
| posted on 17/6/11 at 01:00 PM |
Again, as per other post, told it would end up i a pile of molten mess LOL . If its a 'mess around; and you've got another engine, go
for it. I,ve got a gas flowed head for a sc28, if you want it FOC
ANdy
gaz_gaz
| posted on 17/6/11 at 05:03 PM |
turboblade
Regards Mark
sorry to but in, is this Lydden on Saturday the 25th June by any chance?
wouldnt mind coming to see some kitcars, almost booked this day myself.
mark chandler
| posted on 17/6/11 at 05:19 PM |
Yes, 25th
mark chandler
| posted on 22/6/11 at 06:18 PM |
Not anymore, cancelled so off to Woodbridge instead now.
ianjenn
| posted on 24/6/11 at 09:10 PM |
i am playin with supercharging thro bike carbs with an st170 engine. Things seem to be going ok. Its just a matter of ensuring you pressurise the
carbs and adjust the fuel pressure according to boost.
picture here
[Edited on 24/6/11 by ianjenn]
