hootsno1
| posted on 18/6/11 at 09:56 AM |
duratec fuel pumps
Hi all
Im looking to buy fuel pumps for my duratec 2.0 what pumps are you using to fill the swirl pot and what pump should be used to feed the TBs please.
If a little hammer won't fix it get a bigger hammer
big-vee-twin
| posted on 18/6/11 at 12:06 PM |
You need a low pressure pump into the swirl pot like a Facet Purilator
and a Bosch 044 high pressure pump out of the swirl pot serving the rail.
Personally I have only one pump as I have a swirl pot built into my tank
http://www.triangleltd.com
karlak
| posted on 18/6/11 at 12:09 PM |
Any idea where is the best place to get a Fuel Tank with a Swirl Pot fitted inside ?
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
big-vee-twin
| posted on 18/6/11 at 12:14 PM |
I got mine from alloy racing fabrications
[img]
  Fuel Tank In
[/img]
[img]
.jpg) .jpg) Fuel pump position
[/img]
[Edited on 18/6/11 by big-vee-twin]
hootsno1
| posted on 18/6/11 at 12:20 PM |
Thanks for the info on the fuel pumps big v-twin.
As for the swirl pot in the tank i have an exturnal one that sits on top of fuel tank bought on the bay for only £32 and made with all the pipes where
i want them, look up COOK_38 he may be able to help you
karlak
| posted on 18/6/11 at 03:21 PM |
Cheers Vtwin
Will give them a call.
big-vee-twin
| posted on 18/6/11 at 04:04 PM |
Make sure your high pressure pump is fed by gravity as they don't like to suck the fuel in so it needs to be lower than your output connection
on the swirl.
hootsno1
| posted on 18/6/11 at 06:26 PM |
thanks for that i have planned to place the pump above the swirl pot.
daniel mason
| posted on 18/6/11 at 06:54 PM |
you're make a good job of that car big vee twin! looks fantastic.
