Project7
| posted on 24/7/04 at 09:06 PM |
Zetec Water Pump
The zetec engine Im using has the re-designed water pump, and I cant source a kit to convert it to run clockwise - so that i can run a triangular belt
(crank pulley/water pump/alternator).
Does anybody know if there such a kit on the market?
Failing that I can probably get a mirror image of the impellor machined in which case would anybody else be interested in one? (their cheaper by the
dozen)
Tony
zetec
| posted on 25/7/04 at 06:28 AM |
A bit easier than that. If you have a Mondeo water pump which runs off the back (smooth pulley) of the belt and you want it to run in the same
direction as the crank pulley just change it for a Ford Fiesta 1800 pump fitted with a grooved pulley (few quid from Ford dealer). The impeller is set
to run in the opposite direction to the Mondeo one. Suspect Escort pump the same..
zetec
| posted on 25/7/04 at 06:33 AM |
Just noticed from your site you have a later engine, info correct for earlier zetec, check before you buy for later engine.
I take it you know you will be stuck with fitting a cat for the SVA. Most use earlier engines which don't need one.
Project7
| posted on 25/7/04 at 06:50 PM |
The water pump i have is like the one on this site (about half way down the page)
http://www.fiestaprojects.com/fiestaprojects/zetec.html
When I asked a ford dealer about the escort water pump he pretty much said I would have to buy an escort pump and find out, which was a special order
and I *might* not be able to return it
Burton Power said I could go for an eletric water pump (which they dont sell) or a kit which is driven from the cam belt and I didnt fancy that
much.
My website is well out of date, I will try to get round to updating it soon.
Yeah I know about the problems with using a later engine, but its in the car now so I'll have to live with it
zetec
| posted on 26/7/04 at 07:34 AM |
Go down to Halfords and have a look, they normally have them on the shelf and normally willing to let you check the pump is right before you buy.
SeaBass
| posted on 26/7/04 at 09:42 AM |
You cannot change the pump on the Phase 3 engines to solve this problem. It is only available with one impeller style.
You'll have to make up an idler to the right of the pump for the belt to pass round. I've made up a idler assembly to run the belt what
they called "serpentine" fashion.
Will try and post pics later.
http://www.zetec-cat.co.uk is helpful for this install.
Project7
| posted on 27/7/04 at 08:09 PM |
That web site looks good.
Thanks for your help
bob
| posted on 27/7/04 at 09:48 PM |
And another
http://www.zetecinside.com
Big Stu
| posted on 31/7/04 at 05:43 PM |
The altenator can be fitted backwards to get round this problem. See picture.[img]http://locostbuilders.co.uk/upload/a128060-alternator[1].jpg[/img]
