redeye
posted on 29/7/04 at 08:51 AM |
HELP!!! fuel line
hi guys
im getting near to startin my engine and need some help with the fuel line
im using a 1.8 pinto on carbs
wat i need to know is how the fuel line should be set up
it would appear that the 1.8 has a mechanical fuel pump.
does the 2.0 litre have this?
could any1 tell me if i need a electric fuel pump or a return pipe.
ive tried looking in the haynes manual but it deosnt seem too clear about the 1.8 engines
cheers
patrick
[Edited on 29/7/04 by redeye]
Viper
posted on 29/7/04 at 08:58 AM |
The mech pump is up to the job, would even run a pair of 40's, you don't need an electric pump though most of us favour them.
The return pipe is not needed when using carbs and a low pressure pump.
redeye
posted on 29/7/04 at 09:50 AM |
cheers viper
im i right in thinking that the 2.0 pinto deosnt have the mechanical pump?
Viper
posted on 29/7/04 at 09:55 AM |
most pintos have the mech pump unless they were injected.
James
posted on 29/7/04 at 10:26 AM |
I've fitted my 2.0i to run carbs. I got the mechanical pump from a 2.0- it's a bolt on fitment.
HTH,
James
