Author: Subject: Alternator for duratec
neilp1
posted on 9/8/11 at 07:53 PM Reply With Quote
Can anyone recommend an alternator for a duratec build. Locost option prefered!!
Neil
big-vee-twin
posted on 9/8/11 at 08:06 PM Reply With Quote
No such thing as a locost option when installing a Duratec -I should know.
You need a Nippon Denso Alternator 40amps such as the one sold by Brise. I couldn't get anything else to fit between the chassis rail and engine. I suppose that would depend on relative position of triangulation and engine.
They are only 100mm diameter so easily fit anywhere.
http://www.triangleltd.com
pjay
posted on 9/8/11 at 08:46 PM Reply With Quote
I'd say cheap and very much cheerful would be the loathed Lucas alternator ( ). In my conversion from Pinto to Duratec kept mine to the keep the cost down and save on wiring changes (minor reason):
Aux drive belt set up
Top adjuster came from Tiger and bottom mount I made myself. Sorted the rest of the auxilary drive belt set up myself - all working well for the last 4 months and a fraction of the overall cost
Off the shelf alternator/aux drivebelt set ups can be significant money (see Raceline etc.).
flak monkey
posted on 9/8/11 at 08:58 PM Reply With Quote
Yep, Honda Prelude 2.2 is the smallest Denso I could find. Paid a tenner for one off ebay when I did mine.
Pics in my photo archive in the duratec folder.
Sera
http://www.motosera.com
big-vee-twin
posted on 9/8/11 at 09:01 PM Reply With Quote
I initially went for a low cost option using a Micra alternator pictured below utilising a focus spring loaded tension pulley.
Unfortunately was too big so changed it for the smaller denso unit, made all the brackets myself.
I got the Denso unit from ebay for £62.00 so not too bad.
Think the belt arrangement is much simpler with unit on intake side however.
[img] micra alternator - too big
[/img]:
