karlak
| posted on 10/8/11 at 06:50 PM |
Type 9 Gearbox - What is this wire ?
I did ask this in another thread which is quite long, so may have been missed.
Does anyone know what this wire and connector is for on the Type 9 gearbox in my MK Indy? It is on the opposite side to the mechanical speedo cable.
It was/is not connected to anything.
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
DIY Si
| posted on 10/8/11 at 06:56 PM |
Electronic speedo input?
Sun Tzu, The Art of War
Daddylonglegs
| posted on 10/8/11 at 06:57 PM |
That would be my guess too
big_wasa
Electronic speed sensor (Hall affect sensor). Found on later boxes where the engine was efi.
If your speedo takes a signal from a hall affect sensor its much better than magnets glued to the prop.
karlak
| posted on 10/8/11 at 07:07 PM |
Excellent - cheers guys. I will extend the wires ready for when I change to a Digi-Dash
big_wasa
| posted on 10/8/11 at 07:13 PM |
Brown is earth
black is switched 12v
Yellow is the signal
"FROM MEMORY"
stevegough
| posted on 10/8/11 at 07:54 PM |
That's dead posh, that! mine aint got one of them gizmos.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
robinj66
| posted on 10/8/11 at 09:40 PM |
Fitted on 2.0 Granada's I believe
[Edited on 10/8/11 by robinj66]
jollygreengiant
| posted on 10/8/11 at 10:39 PM |
Correct.
I got one.
| posted on 11/8/11 at 07:29 AM |
I've got the right sort of gearbox - can't find a gizmo to fit to it...
Once I've got one I can think about putting that box on the bench and maybe fitting an upgraded 1st gear... sometime, when money allows...
