Author: Subject: megajolt-zetec
lewis
posted on 20/8/11 at 05:58 PM Reply With Quote
megajolt-zetec
hi all im trying to get all the bits i need for my zetec conversion before the winter season so a few questions
is this megajolt a 3D? does it matter if not? i have a blacktop 2.0l zetec and will be running zx6 bike carbs & 1.8 zetec flywheel + tps
http://trigger-wheels.com/store/contents/en-uk/d32.html
thanks in advance
lewis.
[Edited on 20/8/11 by lewis]
karlak
posted on 20/8/11 at 06:16 PM Reply With Quote
As I understand it.
What makes a Megajolt "3D" will be the fact that it has some type of feedback sytem.
This can either be in the form of a MAP - inlet manifold pressure sensor, or a TPS (Throttle position sensor). Either of these systems will allow the Megajolt to alter the timing etc depending on the engine load/performance.
My set-up I had in the Pinto was a "2D" as it had no TPS or MAP. it purely worked on engine revs - As the revs changed so did the timing advance/retard to the ignition. Evene this was head and shoulders above the dizzy set-up, especially cold starting.
I am sure the above is not the full answer and others may well say I am wrong . But, I am quite pleased how much I have learnt in the last year or so (or think I have )
Now to start getting my head round the injection OMEX 600
So, in summary, you will need either a TPS running from the carb spindle, or a MAP sensor taken from the inlet manifold.
EDIT - Just noticed you mention you have TPS. So just hook up the TPS wires to the MJ, get a suitable map and you will be 3D
[Edited on 20/8/11 by karlak]
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
posted on 20/8/11 at 07:09 PM Reply With Quote
The new edition of PPC mag may be of help , it has an article on fitting and setting up Megajolt. I haven't had a chance to read the full article yet but it should be of help?
lotusmadandy
posted on 20/8/11 at 07:23 PM Reply With Quote
Hi Lewis,
Yes megajolt is 3D if you use MAP or TPS.
whitestu
posted on 20/8/11 at 08:02 PM Reply With Quote
My setup is exactly the same as yours - 2.0 Blacktop and ZX6 Carbs. The carbs should have a TPS if from a recent model and work great on that engine.
If you need a megajolt map let me know as mine seems pretty good. My carbs are running 1.6mm jets.
Stu
lewis
posted on 20/8/11 at 08:23 PM Reply With Quote
thanks for the replys guys ill think ill order one of them & whitestu a copy of your map would be fantastic! u2u sent
