neilp1
posted on 26/8/11 at 12:28 PM |
Main bearings on duratec
Going to be fitting my nice new shiney raceline sump and have wondered about changing the main bearings. Can this be done without removing crank.
infact I don't really want to remove anything if possible!! Anyone done this?
Neil
Paul Turner
posted on 26/8/11 at 01:41 PM |
If you think the engine requires new main bearing it will require a full rebuild in reality, not worth doing part of the job. Unless you remove the
crank you can only get at 1/2 of the bearing thus whats the point. If it ain't broke don't fix it.
Paul
big-vee-twin
posted on 26/8/11 at 02:39 PM |
I decided that I would change the con rod bolts to ARP one's and thats all I did
http://www.triangleltd.com
snapper
posted on 26/8/11 at 06:56 PM |
Don't change them unless you know they need it, current Ford/Mazda engine bearings last a very long time unless they have been oil starved.
I eat to survive
I drink to forget
neilp1
posted on 26/8/11 at 07:41 PM |
Well cheers for that guys. Going to fit sump over the weekend. No further work required!!!
