brianl0922
posted on 3/9/11 at 01:08 PM |
Zetec Camshafts
I have a pair of 2L camshafts from a 1999 Mondeo. Can I swap these with my 1.8 silvertop Zetec, and if I did what advantages in power etc. can I
expect. (Fisher Fury 1.8 Zetec on twin 40 DCOE Webers standard EDIS ingnition.)
Brian
mrwibble
posted on 3/9/11 at 01:11 PM |
might get 15bhp. should fit no problems.
If they both silvertops then yes, I did that... expect about 10bhp extra.
mrwibble
posted on 3/9/11 at 01:19 PM |
didn't know there was a difference between blacktop and silver top cams, is this because of 1 having hydraulic and 1 solid lifters?
r1_pete
posted on 3/9/11 at 01:34 PM |
Yes, the blacktop cams are slightly more radical, they dont have sich a gentle slope to lift the follwers, if you use blacktop cams in a silvertop
expect faster follower wear, especially if you hammer it.
brianl0922
posted on 3/9/11 at 03:33 PM |
Thanks for the responses but does it make any difference if the 2l camshafts work on solid tappets will it still work on the hydraulic tappets in the
1.8
Brian
BaileyPerformance
posted on 3/9/11 at 09:15 PM |
1.8
Brian
Hi, you cannot fit blacktop cams (solid followers) in a silvertop engine (hydraulic).
You need a pair of 2.0L cams from a silvertop 130bhp mondeo to hop up your your 1800.
austin man
posted on 3/9/11 at 09:33 PM |
around 10bhp silvertop to silvertop make sure you fit the right cam to eacjh ie inleyt and exhaust they can be differentiated by the inlet having
another lobe for the cam sensor.
Definitely worth it and a cheap upgrade
brianl0922
posted on 4/9/11 at 08:41 AM |
Thanks all
The cams are from a blacktop so will be no good for my 1.8 silvertop.
will121
posted on 4/9/11 at 06:58 PM |
ive got a spare set of 130 silvertop cams you can have for £25 +postage, what is your current set up, 115 cams, ecu/bike carbs? as may need other
adjustments to get most them
