Author: Subject: What senders?
turnipfarmer
posted on 6/9/11 at 04:20 PM Reply With Quote
What senders?
Hi, folks...
I'm going to be running a standard Ford ECU & engine loom on a new Zetec blacktop that's going into my se7en style.
The ECU, engine loom, transponder etc will all come from a donor car, also running a Zetec blacktop.
The throttle body & injector rail/loom will be those supplied with the new engine.
So then... what does the ECU actually need and expect in the way of inputs and outputs, to run the engine properly?
I've got a pinout for the 104-pin ECU but it seems to me that quite a bit of this is redundant. The car won't have things like aircon - probably not even a heater!
A list would be appreciated.
Thanks in advance.
big_wasa
posted on 7/9/11 at 05:59 PM Reply With Quote
Must have
Maff
Hego / Lambda
Air temp
Water temp
Crank position
Cam position
Tps
It will run fine with out
Clutch position
Ac
heated screen
Smart charge alternator control
evap
It seems to run fine with out Speedo signal but I may retro fit that.
