Author: Subject: ARP Flywheel bolt lube
neilp1
posted on 15/9/11 at 02:50 PM Reply With Quote
Do I need to use ARP assembly lube for my flywheel bolts or can I use loctite thread lock. I have 243 and 270 loctite. If I can use loctite what torque setting should I use?
Cheers in advance,
Neil
perksy
posted on 15/9/11 at 04:06 PM Reply With Quote
If your fitting ARP fasteners you must use their assembly lube otherwise the torque settings/pre-load will be wrong
If you have a look on their website there is a video showing how in-accurate the torque settings will be if you don't use the proper stuff...
snapper
posted on 15/9/11 at 10:04 PM Reply With Quote
You can fit without there lube but should look up the required torque using oil as the lube.
Critical bolts such as mains, head and con rods deffo use lube.
The flywheel bolts whilst critical are much stronger than standard and can take a degree of over torque.
Locktights a good idea.
I eat to survive
I drink to forget
