Author: Subject: Can I put 10mm spacers under engine mounts to stop exhaust manifold touching chassis?
adrianreeve
posted on 16/9/11 at 09:52 PM Reply With Quote
Just discovered that my exhaust manifold touches the top chassis rail - grrrrrr! My choices are pie cut the manifold tubes near the flange and bend the whole thing up, or put 10mm spacers under the engine mounts to raise the front of the engine. Would this cause problems with the gearbox mount being permanently misaligned, and will the slight change of prop shaft output angle wear the pro shaft quickly?
Adrian
mookaloid
posted on 16/9/11 at 10:20 PM Reply With Quote
no problem doing that at all - as long as the bonnet still goes on.
It will make very little difference at the prop end of the gearbox IMHO.
I did this using marine ply spacers on my car.
stevebubs
posted on 16/9/11 at 10:23 PM Reply With Quote
If it fixes the issue, JFDI...
adrianreeve
posted on 16/9/11 at 10:25 PM Reply With Quote
Like your thinking there Steve!
Adrian
snakebelly
posted on 17/9/11 at 06:26 AM Reply With Quote
10mm! just bought 2 chunks of 2 1/2" ali bar stock 3 inches long to make our engine spacers!!!!!!
zilspeed
posted on 17/9/11 at 06:39 AM Reply With Quote
Your engine will move much more than 10mm in the general run of things anyway.
Either use the spacers or a large percussive adjusting device.
use the ball pein end of the percussive adjusting device.
40inches
posted on 17/9/11 at 09:25 AM Reply With Quote
posted on 17/9/11 at 01:18 PM Reply With Quote
If you are using LandRover mounts you can get similar but thicker engine mounts .
adrianreeve
posted on 17/9/11 at 01:20 PM Reply With Quote
I just had the same thought about the thicker mounts!
Will have a look when I get home
Adrian
posted on 17/9/11 at 01:33 PM Reply With Quote
Jaguar XJ6 series 1 & 2 mounts. --- very similar to Landrover but they have an extra metal interleave & sandwich of rubber.
