neilp1
| posted on 19/9/11 at 05:36 PM |
Duratec sensor placement
Where do I put my air temp sensor and water temp sensor for an omex 600 for a duratec installation?
Neil
se7ensport
| posted on 20/9/11 at 07:27 PM |
Air temp: within the airbox as near to the trumpets as possible.
Water temp: same as standard, try and fit it in to the housing at the rear of the engine.
neilp1
| posted on 20/9/11 at 08:23 PM |
If you put your water temp sensor there where do you put your water temp sensor for your gauge?
pjay
| posted on 20/9/11 at 08:45 PM |
I've got an ETB Tiger water temp gauge so I fitted the sender into the rear of the water distribution/coil pack mount. Drilled and tapped.
