<<  1    2  >>
Author: Subject: Zetec setup advise
monck
posted on 28/9/11 at 06:06 PM Reply With Quote
Zetec setup advise
Hi there, want advise what setup i should go with
I had twin 40's on a MJL ignition and 130 spec cams running my 1.8 (no idea what the engine put out) Im changing to a New crate 2.0 zetec
I need advise on my new setup , I don't want to spend 1000s ( if i wanted massive power i wouldn't have got a zetec but i was hoping to get 170-180 hp )
I was thinking maybe selling my 40's for 45's or 50's and fitting some half good cams + setting up on the rolling road will this achieve that sort of power ?
Throttle bodies just seem to expensive unless anyone on hear makes bike Tb setups i think its a no to tb's i dont have great knowledge of electrics either !!
also has anyone used Cams from america they seem good prices £250 and offer lifetime warranty againsed manufacture defects (Or am i missing something )
Ryan
austin man
posted on 28/9/11 at 06:11 PM Reply With Quote
with a decent set of cams and TB's yo may get around that mark. A stage 3 head lightened and balanced. race cams and a rolling road will get 200ish (figures base on a silvertop)
monck
posted on 28/9/11 at 06:13 PM Reply With Quote
So with say i stay with twin 45 webers and cams ill be at what 160 ?
carlknight1982
posted on 28/9/11 at 06:30 PM Reply With Quote
dont forget you need a well designed exhaust to help flow the gases too.
Logic will get you from a A to B
Imagination will take you everywhere.
AndyW
posted on 28/9/11 at 07:04 PM Reply With Quote
gbs inlet plenam, with an emerald ecu gave 166bhp on crate engine. Cheap as chips.
austin man
posted on 28/9/11 at 07:26 PM Reply With Quote
emmerald is about £400 for a mapping session you could convert the webbers to work as TB's and inject it I think you could get 160 on carbs and megajolt, bike carbs offer more economy
skidmark
posted on 28/9/11 at 09:09 PM Reply With Quote
My standard 2.0 Blacktop zetec with custom inlet plenum (similar to the GBS one), a GBS exhaust manifold and megasquirt was rolling roaded at 162bhp (at only 6500rpm). Driveability on road is good too (or it was until somebody crashed into me!!!).
monck
posted on 28/9/11 at 10:16 PM Reply With Quote
Ok so IF i went (bike) tb's would they produce around 170 with cams ?? ... Bike tb's seem to be the cheapest way but what is the disadvantages over likes of jenevvy style bodies...
I know the bike tbs arnt to dear and neither the manifold if you make one or have one made ... its just the ecu and that i don't understand am i just making a mountain out or a mole hill or are they really that complicated going form webers to tb's ?
If i sold my webers how much very roughly would i have to spend on top to get a bike tb setup ?
Would tb's without cams be better than webers with cams?
sorry for all questions
Paul Turner
posted on 29/9/11 at 01:13 PM Reply With Quote
My original 2.0 Silvertop made a corrected 178 bhp at the flywheel on both Noble's and Vessey's rolling roads. The engine was totally standard except for a pair of 45's (36mm chokes), a pair or Kent FZ2002 cams and a nice 4 into 1 exhaust (1 3/4 primaries, 2 1/4 main pipe).
I would expect a standard Blacktop to make a bit more since it has slightly bigger inlet valves but remember that whilst fitting hydraulic cams to a Silvertop is a doddle fitting the mechanical cams to a Blacktop requires shims which is very time consuming.
My own car now has a totally standard Blacktop fitted with 45mm Jenveys and a MBE ECU. When I did some work with a data logger on both this engine and its predecessor (a totally standard Silvertop on the same Jenveys, ECU and exhaust) the result showed the Blacktop was slightly quicker.
Unless you are really pushing on during a track day the standard engine is quick enough on the road, if anything the flexibility makes it quicker low down.
monck
posted on 29/9/11 at 04:24 PM Reply With Quote
Hi Paul
your saying 178bhp with cams and 45s do you mean size of throttle bodies or are you talking webers ? ?
i have a good 4 into one exhaust on my kit car so that's not a problem ...
The reason im asking all this is i don't want to get in it and not feel a difference between this blacktop and my old 1.8 engine
Paul Turner
posted on 29/9/11 at 05:43 PM Reply With Quote
I said 45's with 36mm chokes, throttle bodies don't have chokes therefore I was referring to Webers.
If you replace a 1800 Silvertop with a 2 litre Blacktop and use all your old bits you will definitely notice a difference. The 1800 Silvertop came in various flavours and none were as powerful as the 2 litre.
monck
posted on 29/9/11 at 05:50 PM Reply With Quote
Sorry i didn't click when i read it the first time
178 hp seems very good !!
Did you have verniers with the cams?
Any idea the best place for price on those cams ?
Sorry about all the questions !
cheers
Paul Turner
posted on 29/9/11 at 06:01 PM Reply With Quote
Those cams are no good with a Blacktop, they are hydraulic profiles, you need profiles for solid lifters with a Blacktop and as I said above fitting is tiresome.
I did not have verniers. When I fitted the cams as per the suppliers suggestion I used the slots as per Fords standard installation, gave 178 corrected BHP at the flywheel. Later I timed them in as per Kents instructions, Ford cam wheels are not dowled thus verniers are not strictly necessary but they make the job way easier, took me most of the day to get it right, with verniers would have taken an hour. Took it back to the RR and it gave 178 corrected BHP at the flywheel but it had way more midrange power which was great but it was nowhere near as good or smooth low down, a right pig in town to be honest. When I sprinted it the times were no different.
If you want some advice run it as standard to begin with and upgrade if you feel the need. I hav'nt yet.
Paul
BaileyPerformance
posted on 29/9/11 at 06:50 PM Reply With Quote
Hi, see link, stock engine 2.0L
http://baileyperformance.co.uk/?p=184
Good look with your project.
monck
posted on 26/10/11 at 05:26 PM Reply With Quote
Hi again everyone , after reading and asking alot i have a better understanding now of power a zetec should give
I need your opinion !!!! Here's my thing
My 1.8 had 2ltr cams lightened flywheel on 40 webers and to be honest i wasn't blown away i expected MORE !!
This 2.0 although its new its still only going to give around 160 on throttle bodies
I don't want to get it set up mapped ect and take it out next year and be disappointed by its performance and i have a feeling i might ??
I want something that will scare me abit
I don't want to turbo , and cams are around £400 and ported head around £750 from places i have asked alot of money for the gains ?
Are these prices right ? what is the best value for money to get more hp?
My opinion always has bin a bigger engine or more powerful one is always cheapest route ? should i consider a u-turn and go Duratec ?
Or should i just shut up and carry on with zetec ?
BaileyPerformance
posted on 26/10/11 at 06:02 PM Reply With Quote
why bother with an 1.8L when a 2.0L is available at less than £200?
Use a stock 2.0L black top on EFI with bike or jenveys and leave it at that, cams are not worth the money for the power you gain (less than 20bhp for fast road)
Dont bother with carbs, they are a thing of the past!
monck
posted on 26/10/11 at 06:15 PM Reply With Quote
Im not thinking of a 1.8 dont worry i think i explained it wrong or you read it wrong not sure .....
Sorry if it was the way i wrote it !! But basically i have removed a 1.8 on twin 40's but was never that impressed with performance to other cars i had driven it didn't feel as quick as i expected it to be when i bought it
I bought a 2.0 blacktop new and plan to use gsxr tb's on megasquirt ! Forgetting Hp figures i must be right in thinking its not going to be a huge amount quicker ?
I want something that feels a fair bit quicker than before and im not sure a stock 2ltr will achieve this ?
BaileyPerformance
posted on 26/10/11 at 06:37 PM Reply With Quote
Oh sorry! I must learn to read!!
A good 2.0L on bike TBs on MS (preferably MS2) will make 160-170BHP and about the same torque, will feel quick in a light car.
A good 1.8L (same as above) will make 140BHP.
I would suggest (after driving several zetec powered 7 type cars) 170BHP is quick enough, 0-60 been around 5 seconds.
I have done cars with tuned V8's and they are not much quicker, getting the power to the road starts to become a problem much after 200bhp.
Paul Turner
posted on 27/10/11 at 06:47 AM Reply With Quote
If 170 bhp isn't enough for you sell the car and buy a superbike.
Paul
DixieTheKid
posted on 27/10/11 at 07:08 AM Reply With Quote
Go for a set of Kent fast road cams think thier 2002's, i would suggest while the cams are out having the head polished if you want the 180bhp. You get close without any head work, but defo will be the cams.
Try to run with TB's if you can, failing that look out for an ST170 manifold and a set of bike carbs.
COS IT'S Worth IT
Paul Turner
posted on 27/10/11 at 07:12 AM Reply With Quote
I posted above that Kent FZ 2002's are no good in a Blacktop, they are Silvertop hydraulic profiles and a Blacktop uses solid lifters.
Bailey performance reply is total sense, try the car before you spend any more money, think you will be very satisfied.
DixieTheKid
posted on 27/10/11 at 08:14 AM Reply With Quote
I think your find that just the ST170 had solid lifters, and the Zetec E (black top) had machinical lifters do you know the difference?. Paul do you normally talk to people like sh*t?
COS IT'S Worth IT
lotusmadandy
posted on 27/10/11 at 09:18 AM Reply With Quote
zetec e (black top) has solid lifters.
Jenko
posted on 27/10/11 at 11:06 AM Reply With Quote
I've not read through the entire thread but.....
First off, everyone wants a 'cheap power upgrade'...Reality is of course that this does not exist. What ever happens will cost money.
So with a standard 2.0ltr engine with either TB's or carbs you will see around 160bhp. Changing cams is great, but to release the full potential of longer duration and higher lift cams a head port would help.....with sensible cams and a head port you would expect around the 180bhp mark.
Going to fuel injection will not mean that you get more power, just more drivability, possibly torque lower down the rev range, and considerably better fuel consumption...but well worth thinking about as you engine is designed for this (i.e. you have the sensors required. Many of us 'locost' have done this using motorbike TB's and MegaSquirt which will do the same job as jenveys and omex, all be it a bit more of a job to install.
MY BLOG - http://westfieldv8.blogspot.co.uk/
Paul Turner
posted on 27/10/11 at 11:38 AM Reply With Quote
The Zetec E Silvertop uses Hydraulic Lifters (also called tappets). The ST170 engine and Zetec E Blacktop are basically the same engines but the ST170 has a VVC mechanism and more power, it also has certain internal differences to make it slightly stronger, both these engines use Mechanical or Solid lifters, they are the same thing, different people refer to them by different names.
Fitting new Hydraulic cams is a doddle, takes a couple of hours but you must fit new hydraulic lifters, if you don't odds are that you will bugger the cam before you get on the road. Fitting new mechanical or solid cams is a much lengthier process since you need to shim up each follower to the correct clearance which also means having a good stock of shims. Some cam manufacturers claim to manufacture their cams to the manufacturers base circle dimensions but beacuse of manufacturing tolerences you are going to be very lucky if all the clearances are within the recommended figures.
DixieTheKid. Thanks for your really constructive remark, I must remember never to offer you advice. I was simply trying to stop Monck buying the wrong cams for his engine, fitting the FZ2002's would have resulted in several hundred pounds worth of scrap components. Have a nice day.
Paul
<<  1    2  >>
