Author: Subject: low oil pressure
Valtra
posted on 2/10/11 at 10:56 PM Reply With Quote
low oil pressure
Went out for a blast late this afternoon for the first time in nearly 2 months as I've been so busy working and sorting out my sons uni. accommodation .
couple of times the oil light came on which has happened before when getting "enthusiastic" round a roundabout but usually takes a lot of provocation . then to my horror I noticed the oil pressure gauge showing only 1 bar pressure , I instantly dropped the pace and cruised gently home . Pressure was fine when I first struck up and I'd checked the oil , also fine .
What's the first thing to check? oil pump? engine seems to be running free enough
"If it looks like it works and it feels like it works, then it works"
snapper
posted on 3/10/11 at 05:42 AM Reply With Quote
Check pick up is not full of crud
I eat to survive
I drink to forget
Valtra
posted on 3/10/11 at 06:59 AM Reply With Quote
Hi
thanks , still a sump off job though! shouldn't be any crud in there but will check.
posted on 3/10/11 at 06:53 PM Reply With Quote
The first thing to check is that you have an oil pressure problem rather than a gauge problem, test the pressure with a workshop type gauge before stripping anything.
Valtra
posted on 3/10/11 at 09:10 PM Reply With Quote
good point
matt_gsxr
posted on 3/10/11 at 09:24 PM Reply With Quote
Oil level. Sometimes it is the simple things.
Valtra
posted on 3/10/11 at 09:51 PM Reply With Quote
I checked before the journey but not since , will do thanks
