GRRR
posted on 5/10/11 at 07:52 PM |
Do i need a locknut on my TRE?
Quick question cause I'm in the garage! Do my track rod ends need locknuts against them?
blakep82
posted on 5/10/11 at 07:57 PM |
yes, very much so!
________________________
bikenuts
Quick reply; Yes.
steve m
posted on 5/10/11 at 08:02 PM |
If you want your steering to remain steering, and constant, with both wheels pointing the way they should
YES
[Edited on 5/10/11 by steve m]
Danozeman
posted on 5/10/11 at 08:19 PM |
A definate YES or they unwind them selves and you will end up with no steering.
Dan
indykid
posted on 5/10/11 at 08:42 PM |
Is that a welded track rod?
I thought welded steering components were an MOT fail?
GRRR
posted on 5/10/11 at 08:52 PM |
Ok cool thanks all, reason for asking was that the steering arms don't rotate and neither TRE came with a locknut so I wondered if it
wouldn't be able to unwind. Now to find locknuts, IVA on Monday!
The rack was provided already modified by GBS so hopefully is ok!
ashg
posted on 5/10/11 at 09:25 PM |
they will rotate put a pair of mole grips on them and turn rally design stock them as a last resort usually next day postage too .
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Macbeast
posted on 5/10/11 at 09:36 PM |
Why do people not reduce the size of their pics before posting ???
40inches
posted on 6/10/11 at 07:35 AM |
What are you viewing on? Only half a screen on a 22" monitor.
posted on 6/10/11 at 08:39 AM |
I have a 23" monitor and it takes nearly twice the width of my screen. Size is not important (they say!), the resolution settings determine how
much space a picture will take.
Most locosts have welded steering columns.
posted on 6/10/11 at 10:25 AM |
I thought that was the case too ... but from LR forums there are many with welded steering rods plus as ^^^ says, welded columns, indeed mine is one
of them - bear also in mind it is far easier to spot a welded track rod than a welded coloumn.
BTW - I had similar porblem to you in that my steering rods were too short and the usual slution is to make up extensions so no welding involved. You
need to be sure of the weld too, lemme find the welded track rod as I received my car.
If you are needing M14 half nuts, then I have some squirrelled away so pm me, pretty sure I can do them cheaper than rally design.
here it is:
[Edited on 6/10/11 by 02GF74]
