Nickp
posted on 6/10/11 at 01:29 PM |
Sump clearance?
I've been getting friendly with my angry grinder this week to get a BMW M52 6-pot into my Haynes chassis. The engine / box is now sat snuggly in
the hole but I just need to get it in the 'best' position now. What would be considered the maximum amount for the sump to poke below the
chassis? BTW - What would be the norm for chassis - ground clearance? 100mm or more?
Thanks in advance,
Nick
matt_gsxr
posted on 6/10/11 at 01:36 PM |
UK speed bumps and cushions can't be taller than 100mm.
Some people go lower, but search on damaged sump if you think that is a good idea.
rodgling
posted on 6/10/11 at 01:38 PM |
I'm running about 100 mm with an m3 (formerly a 328) and that seems reasonable to me - it will get over speed bumps if I'm careful.
[Edited on 6/10/11 by rodgling]
Nickp
posted on 6/10/11 at 01:46 PM |
Thanks guys
So, 100mm sump to ground clearance absolute minimum then?
Any idea on chassis to ground clearance for a Haynes Roadster so I can work out roughly how much I can poke it below the rails. I do hope to have some
sort of sump guard, like a rail that sits a smidge below the sump to take any hits rather than the ally sump.
tilly819
posted on 6/10/11 at 02:09 PM |
ide say so, i went out at the weekend with the new s2K engine in with about 75mm clearance, bottomed out the suspension in a big dip in the road and
put a hole in the sump
clearance depends on ride hight settings on the shocks and what size tyres you are using best bet is to take the springs out and let the suspension
fully compress onto the bump stops and see how much clearance you have or if the sump is on the floor how much suspension travel you have left before
your on the bump stops
and yes fit a sump guard
tilly
[Edited on 6/10/11 by tilly819]
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
owelly
posted on 6/10/11 at 02:25 PM |
My Alfa engines had 50mm clearance which was ok if driven carefully. What wasn't so good was the bellhousing which was level with the bottom of
the sump but because it was behind the front axle-line, touched-down very easily!
http://www.ppcmag.co.uk
Nickp
posted on 6/10/11 at 02:32 PM |
tilly
Problem is, I only have a bare chassis with the engine/box sat in it. No suspension, wheels etc etc so I've no idea what the chassis to ground
clearance is going to be. If the chassis clearance will be about 150mm, then I'll know I can get away with the sump dangling 50mm below the
chassis.
Nickp
posted on 6/10/11 at 02:33 PM |
Was that before or after pies mate?
Bluemoon
posted on 6/10/11 at 03:54 PM |
On my MK about 140mm clearance, I want a little more! Ideally level with bell housing and at most 25mm under chassis seems about correct..
Dan
bi22le
posted on 6/10/11 at 04:47 PM |
One thing i have noticed since owning the striker is that the sump is low but right between the front wheels. i am yet to scrape it!!
Just a thought
Please read my ring story:
Nickp
posted on 6/10/11 at 05:36 PM |
Dan
Just to confirm fella, is the 140mm sump or chassis clearance (or both?)
Nickp
posted on 6/10/11 at 05:38 PM |
Just a thought
My sump's gonna be about 3ft behind the front wheels, it's a long old lump the M52 and the sump bowl's at the back
RAYLEE29
posted on 6/10/11 at 06:24 PM |
Hi, according to the book you would be looking at setting the sump height 25mm below the frame rails.
From memory ride height is 100mm clearance frame rails to floor on a standard chassis.
I remember seeing pics on the haynes site ages ago of Chris's brother in laws car which had a six pot bmw lump.
you could always ask on there (I dont go there any more as i have/had a personal dislike of a few peoples attitudes but there is some good guys on
there).
Ray
build diary1
http://picasaweb.google.com/raylee290/RoadsterPics#
build diary2
http://picasaweb.google.com/raylee290/KITCARPICS?authkey=Gv1sRgCI2AouyYgpuQmAE#
