Progress - strip down begins
Evening all,
Well, what a weekend. Got loads done on my engine this weekend, it's going to have a complete strip down to bear block to see if there are any
problems before I clean and paint it all up. Any worn parts out of spec I will hopefully change, budget depending. Car ran fine before I removed the
motor.....
I also finished my work bench, bolted down the vice and installed the speakers, iPhone plugs into a sub and amp in the cupboard.
One thing I will say, this engine ain't light. Nearly blow a gasket trying to move it. But with 220 bhp as standard, I think the overall car
will still be quick.
My work bench now finished.
Had a bit of a job getting the gearbox off last night, this morning first thing it took me about 30 mins... Easy after a nights kip! One problem I
know I have with the engine is the clutch, it did slip a bit when the boost came on and the revs increased. Looking at the plates through the pressure
plate - they don't look that worn.... I did notice that there is a crack on the pressure plate springs and the finger springs don't move
very well in that area. Any one had the same thing? The clutch will be changed, just a matter of interest really. Any one know if these engines (fiat
20v) suffer clutch problems??
Anyway, really feel I have had a good weekend getting covered in oil, shame I have to go to work tomorrow.
Rob
20vt powered rear engined locost
