Author: Subject: Xflow Flywheel - weights?
Dick Axtell
posted on 7/8/04 at 07:23 AM Reply With Quote
Weighed my 1600 flywheel. Scales show 22lbs. Seems too much for GT engine.
Anybody got weight figures for other xflows, or pinto's?
Secondly, is there any reliable info on flywheel lightening e.g. dimensions?
Any input welcome.
Dick Axtell
posted on 7/8/04 at 09:44 AM Reply With Quote
Weights
Wallage book gives weight range from 26 to 16.75lbs., but no weight specific to the GT model.
Still hoping for feedback.
wicket
posted on 16/8/04 at 10:19 AM Reply With Quote
I recently had a new ring gear fitted by out local motor engineers with a good reputation and at the same time I was persuaded to have the flywheel lightened. They removed 8lbs(3.6kg) which left it at approx min weight of the standard Ford weight of 16.75 lbs. The wheel is now fitted and in the car but I read with some concern in 2 places about the potential problmes with machining cast iron wheels, Burton Power in there catalogue say, quote 'Original equipment cast iron flywheels are invariably too heavy and when lightened, should carry a government health warning!', and in the Wallage book they talk about making sure that there are quote 'proper safe radius where they've machined metal off'. Not sure whether there are safe rads, am I worrying unduly, any expert comments would be appreciated.
Dick Axtell
posted on 16/8/04 at 04:43 PM Reply With Quote
Radii
Originally posted by wicket
...'proper safe radius where they've machined metal off'. Not sure whether there are safe rads,...
Think Wallages were referring to edge radii. Apparently aim is to reduce chances of small edge cracks propagating under centrifugal stresses.
