nige
| posted on 7/8/04 at 05:51 PM |
2.0 twin cam efi ford
any one used one ?
any hints or tips would be usefull
thanks in antisipation !!!!!!!!!!!!!!
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
Browser
| posted on 7/8/04 at 07:19 PM |
If you do a search you should come up with the (many) debates seen here in the past about the relative merits of using this engine.
Viper
| posted on 7/8/04 at 07:31 PM |
and not many merits i'm afraid
iwbunting
| posted on 7/8/04 at 08:07 PM |
2.0 dohc ford efi
A lot has been spoken of this engine....
It has got its problems,mainly the cylinder head gaskets prone to fail and head cracking etc.But,if the coolant is kept in top form ie.kept level,most
of the problems can be overcome,also by using a wetting agent the coolant will do its job better.Another area is in the size of the radiator,dont be
tempted to fit a lot smaller capacity one on the basis that the engine isnt going to get as hot,also fit an oil cooler as this will help in 2 ways,it
will reduce oil temperature and the temperature residual carried by the oil itself,and isbt that pricy to do.
Cam chain problems can arise but usually on high mpg only,so changing the chain is the answer,fiddly but doable.
On the plus side,the EFI version pumps out about 125 BHP which stillisnt bad going.
| posted on 7/8/04 at 09:30 PM |
The DOHC is also taller than the Pinto, to sump and bonnet clearance may be a problem.
heinlein
| posted on 7/8/04 at 11:19 PM |
If over-heating is an issue an article in the May Grassroots Motorsports on waterless cooling is worth reading; by switching to a propylene glycol
based cooling medium instead of water/ethylene glycol mix average temperature may actually go up, but the hot spots, which are the real problem,
should be eliminated.
When you're lying in the midst of the Afghan plains and the women come out to cut up the remains; just roll to your rifle and blow out your
brains and go to your god like a soldier.
mangogrooveworkshop
| posted on 8/8/04 at 08:40 AM |
Would make a cracking boat anchor.!
quote: Originally posted by rashandnige
any one used one ?
tom_loughlin
posted on 8/8/04 at 09:36 AM |
i have to say, im a bit dissappointed to hear you guys comments on the 2l dohc engine - i have a sierra with one in, and have been driving it around
to see what the engine is like - its doen 107k miles, and still seems to have plenty of go!
might have to re-think dropping it in my car after sva and registration then, and keep an eye open for a zetec or something.
macspeedy
| posted on 8/8/04 at 10:04 AM |
i asked about this before i got my donor and was steered away due lack of tuning parts for them
iwbunting
| posted on 8/8/04 at 11:18 AM |
2.0 DOHC - Macspeedy
To Macspeedy.......
Some of us are quite happy with 125BHP.
Ok so you have to remake the plenum if you use the EFI,but hey not a big problem.You CAN get hot cams for them giving between 8-15 BHP
increase..no problem.You would also need to fit an induction kit to get rid of the air boxes (again if using EFI) but this could give a possible 5-8
BHP increase.So you could end up with a cheap motor pumping out between 138 and 148 BHP.
macspeedy
| posted on 8/8/04 at 01:58 PM |
in reply
mine is a cheap motor due to me doing all the rebuiling and head work to gain that extra power, it just takes a bit of time, 18 months so far!
iwbunting
| posted on 8/8/04 at 07:52 PM |
In reply ...
Cheap !
I paid £200 for a complete Mot'd,Taxed sierra with only 50k on the clock,with alloys in a well usable condition,a 2.0 125 BHP motor and MT75
box,I thought that is cheap.Maybe not.
Mark Allanson
| posted on 8/8/04 at 08:22 PM |
I think the twin cam does have merits, if you are happy with 125bhp (250bhp per ton is not bad by any standards). Most of its downfalls are due to
abuse, it must be serviced as per ford shedules, especially the cam chain which is an easy swap (just line up the gold links). I am not sio sure that
you would have to remake the plenum chamber as it is only slightly above the cam cover, much easier to raise the nosecone a little (speaking as
someone with a little experience on making plenum chambers!)
If you already have the engine and are happy with it, know its history and don't want to beat Chris Allanson's 0-60 record - go for it
nige
| posted on 9/8/04 at 08:30 AM |
power is not an issue as im not building
to race...........
height is no a prob im 442 , 50mm.above
bonnet line , a scoop will solve that
thanks for the replies..................
what about the sump can it be cut or
is there an alternative ?
Mark Allanson
| posted on 11/8/04 at 06:00 PM |
I had a look at a '96 granny 2.3 today, it looks like the dohc 2.0 as fitted to sierra's, it pushes out 145bhp, for the same dimensions,
the efi is below the rocker cover too!
andyps
| posted on 12/8/04 at 08:01 PM |
Will have to look out for one of those as it is the efi height which I am more concerned about for my build. Not too worried about the engine size as
I plan to build a taller chassis, but would like to not have the efi sticking out of the bonnet!
Mark Allanson
| posted on 12/8/04 at 08:30 PM |
Me neither
andyps
| posted on 13/8/04 at 08:42 AM |
Wow - where did you put it all Mark? That looks really neat, must be quite a change from the original set up.
nige
| posted on 13/8/04 at 07:09 PM |
mark what have you done on the sump
do you know if the steel pinto sump
will fit the twincam block
dblissett
| posted on 14/8/04 at 08:38 AM |
twin cam
i bought a sierra with one of these engines when i started my 442 in fact i have still got it its that good if you want it its free
i ended up getting a pinto because the cost of parts for the twin cam
go to a local motor factor and ask for the prices for both engines full gasket set and cam chain/belt
i was quoted about £100 for a cam chain
then you have to sort the exhaust and the efi sticks up 4" above the cam cover
its a tight fit in a 442 and i came to the conclusion it wasent worth it
if you want cheap thrills stick with a pinto
cheers dave
Mark Allanson
| posted on 14/8/04 at 06:20 PM |
I have chopped the sump and extended it forward, the little box thing that some people weld on usually fouls the clutch, I dont know about a pinto
sump fitting to a TC block, I have been told they are the same, but I doubt it
