blakep82
posted on 15/11/11 at 11:45 PM |
rad fan mounting kit
got one of those £19 radiator fans off ebay the other day, looks good. came with a universal fitting kit that threads through the fins on the
radiator. all good there
the kit consists of 4 plastic ties with securing clips, 8 foam pads, and 4 springs
I'm guessing the order is:
Plastic tie, foam pad, radiator, foam pad, fan, spring, securing clip?
does that sound about right? or does the spring go somewhere else?
________________________
Ben_Copeland
posted on 16/11/11 at 05:38 AM |
I 'think' the spring goes under the fan between the radiator and fan. But I'm sure some one will confirm.
Also expect lots of people telling you not to use that kit.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
robinj66
posted on 16/11/11 at 07:04 AM |
I think the problem that Ben is refering to is that the ties tend to stretch over time and then start to act like a saw, cutting through the rad
matrix. One way of overcoming this is to run the ties through plastic tube . HTH
posted on 16/11/11 at 09:17 AM |
... that's if the ties don't snap when you breathe in their general direction!
It's Evolution Baby!
Craigorypeck
posted on 16/11/11 at 09:23 AM |
I put the spring behind fan... tie-spring-fan-foam-rad-foam-clip.
Makes the most sense to me, I think, the whole operation is kept secure and the spring takes up the slack.
Edit just noticed you did the same just from the other direction... lol
Mines been on for 3 years, driven 3-4 days a week. not moved or caused any damage yet
[Edited on 16/11/11 by Craigorypeck]
blakep82
posted on 16/11/11 at 10:53 AM |
i know they're not brilliant, plan to use a bit of heat shrink to protect the radiator itself, besides the radiator is a second hand effort, so
the ties will do for now til i get a proper new radiator. when that happens i'll look at a proper aluminium mounting thing
but as Craigorypeck says, its as i thought it would be, so thats good.
"for professional installation" was their excuse for not sending out any kind of instructions lol
