karlak
| posted on 18/11/11 at 05:13 PM |
Clutch Hose Kit
Should have my new OBP Pedal box fitted soon, so I now need to set up the Hydraulic Clutch.
Any ideas where I can find a clutch hose Kit with Bleed facility ?
TIA
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
big-vee-twin
| posted on 18/11/11 at 05:38 PM |
Hi Mate,
I made mine up using Goodridge components and pipe from Rally Design they do a Kit too cost about 30 pounds either way.
Use a female bulkhead fitting hose end and the bleed nipple screws straight in
[img]
  Duratec clutch cylinder
[/img]
link
[Edited on 18/11/11 by big-vee-twin]
http://www.triangleltd.com
| posted on 18/11/11 at 07:21 PM |
Quick way is to use a simple short length of standard brake pipe for the bleed pipe, you can either screw a standard 10mm bleed nipple into a
standard female flared fitting (convex-concave double flare) or a better way is to screw a bleed nipple in to a Male to Male brake pipe pipe
joiner.
2 way female joiners for copper brake pipe fittings x 5 | eBay
[Edited on 18/11/11 by britishtrident]
