Author: Subject: Hesitation/misfire/fuel starvation - need a bit of help
carse
posted on 29/11/11 at 03:58 PM Reply With Quote
Hi all,
Did a track day at Oulton park on the 19th of Nov (the other Saturday). Had a really good session driving it hard then came in to swap drivers so the car was particularly warm, it then sat in the queue to go back out on track and preceded to over heat (I'm pretty sure now the radiator fan mustn't be working, most probably a lack of power to the fan or a sticky thermostat).
I let it cool down again and sorted the problem, topped it up with water etc and re-bled the cooling system. But towards the end of the day (maybe an hour or so after the over heat) the engine seemed to develop a little cough/hesitation on full throttle in the upper rev range, say 7-8,000rpm+.
It feels a little like fuel starvation as it's not like a brick wall thing, it will rev out beyond it to the limiter, just with reduced power and definitely not as quickly as when it's on fine form. I'm almost certain it isn't ignition related as it's not a big misfire like a knackered plug or something, it just isn't 100% healthy.
So, to the point. I was wondering if any of you who are more qualified than me could shed any light? Is it a possibility in your opinion that the over heat could have caused the problem I'm experiencing? Blown the head gasket? Or at worst, warped the head?
The engine is a 2004 (K4) Suzuki GSX R 1000 unit in an MK Indy R. It's had new plugs relatively recently so shouldn't think there's a problem there. The only thing is when it over heated, it slightly pushed the coolant pipe off one of the T-pieces so was spraying water/coolant around the engine bay. I would have thought that would have evaporated off fairly quickly due to the heat of the motor/exhaust and then going back out again but could some water have got into an electrical connection somewhere and caused the gremlin?
I've tried to give as much detail as possible so hope it helps.
Any help very much appreciated.
Carse
adithorp
posted on 29/11/11 at 04:31 PM Reply With Quote
Shame there was no hesitation before posting in 3 different sections and thus pushing other peoples threads off the front page.
Can't comment on the hesitation but if you overheat at this time of year then you'll have major trouble in summer. get to the bottom of that and you may find your other problem.
http://jpsc.org.uk/forum/
carse
posted on 29/11/11 at 04:50 PM Reply With Quote
Like I said, the car had had an extremely hard session then sat stationary running, hence the over heat. Has been fine on roads all summer.
"A witty saying proves nothing" - practice what you preach mate. Was only trying to get a bit of advice so thought I'd post it in all relevant forums to my problem. I thought this was meant to be a community where you could ask away and get considered responses from like minded people?
deezee
posted on 29/11/11 at 05:10 PM Reply With Quote
Maybe the overheat was caused by a head gasket problem, over pressurising your coolant system with compression bypass. This pushed off your hose? Happened on an engine of mine! The fault is (through no fault of your own) vague. I'd start with a compression check, check the plugs, check the coils, check you injectors, check the wiring, check your header tank for a head gasket problem. Its also worth fixing your cooling system if your going to thrash it around a race track. Having no radiator or a dodgy thermostat is just asking for an expensive bill!
As for posting in 3 sections, I don't blame you for looking for advice, you've come to the right place. But throwing a few posts onto the front page pushes other peoples posts off, who are also looking for help.
Dusty
posted on 29/11/11 at 05:44 PM Reply With Quote
Essentially you say the car has been fine all summer, fine for the first thrash round the track, then while sat in the queue it overheated and blew off a hose, wetting the under bonnet area and electrics. You fixed that and the car was fine for another hour but then developed a slight missfire and loss of top end power. So it's not even clear if the overheat was related to the problem. Sounds more like the stress of the trackday has caused the problem. Could be almost anything, plug, coil, head gasket, fuel.
I have twice suffered with fuel pickup problems after trackdays, due to the violent sloshing in the tank churning up debris. I don't have an envelope type filter on the tank end of the pickup pipe. Despite flushing my tank to clear the debris, some garages still deposit new gunge when I fill up.
And yes it is a community and you can ask away but as we all see the posts on the front page you have asked the same people the same question three times. Should I put this post on all three of your posts?
[Edited on 29/11/11 by Dusty]
DixieTheKid
posted on 29/11/11 at 07:37 PM Reply With Quote
+1
COS IT'S Worth IT
carse
posted on 30/11/11 at 09:46 AM Reply With Quote
Apologies to all if I screwed things up on the front page. As you can see by my post count I'm still relatively new to posting. I was only trying to get as much help as poss but realise I've messed things up for other users so sorry.
I do really appreciate everyones help and the wealth of knowledge that's on offer to tap into with the locostbuilders community.
I won't make the same mistake twice.
Hopefully there's no bad blood as I know I always enjoy chatting to guys who run seven-a-likes.
Carse
Nick DV
posted on 30/11/11 at 02:28 PM Reply With Quote
Carse,
You don't need to apologise, you didn't screw anything up and no one should feel there is 'bad blood'!! (Not a good way to welcome someone looking for advice to the forum imho!!)
Good luck with the engine, and keep posting
Cheers, Nick
"The force will be with you, always!"
