Author: Subject: Fuel pump connections
theduck
posted on 4/12/11 at 05:22 PM Reply With Quote
I have this type of mechanical fuel pump on the pinto, which is the inlet and which is the outlet?
Thanks in advance.
Davg
posted on 4/12/11 at 06:05 PM Reply With Quote
From your pict
Top - inlet from tank
lower - to carb
cheers
D
theduck
posted on 4/12/11 at 06:08 PM Reply With Quote
Cheers.
lotusmadandy
posted on 4/12/11 at 08:23 PM Reply With Quote
On mine the upper one was to the carb,the lower
one draws from the tank.
Sorry if im confusing you but thats how my pinto pump is.
Just been and checked the pump and thats how it is.
theduck
posted on 4/12/11 at 09:03 PM Reply With Quote
Andy have you got a picture of your pump? Looking at that pic again mine might be very slightly different.
posted on 4/12/11 at 09:05 PM Reply With Quote
You can blow through from inlet to outlet but not from outlet to inlet.
posted on 4/12/11 at 09:06 PM Reply With Quote
One will be an inlet and will have a vacuum when operated, the other, the outlet will have some pressure. Not too difficult to test?
theduck
posted on 4/12/11 at 09:11 PM Reply With Quote
Thanks for the tips on how to check.
lotusmadandy
posted on 4/12/11 at 09:15 PM Reply With Quote
Im not at home atm so cant take a photo.
As already said its easy to check,press the pushrod in by
hand and you will feel air pressure from the outlet.
Andy.
theduck
posted on 5/12/11 at 10:33 AM Reply With Quote
No worries Andy, will check it tonight.
Thanks everyone for the tips. This is all very new to me but I'm learning with all your help, this forum is invaluable!
