Author: Subject: Using flexi joint to provide minor adjustment to exhaust angle?
JekRankin
posted on 15/12/11 at 12:47 PM Reply With Quote
Hi
With my engine in position and the output flange parallel with the diff flange, I need to correct the angle of the output on my manifold by about 4degrees to have the silencer fit inside the sill section.
Originally I was thinking I'd need to chop and weld a 2" dia bend section into the manifold, but I'm now wandering whether I could get away with a flexible exhaust joint, like one of these:
http://www.ojzengineering.co.uk/product.php?product=21
What's the consensus on this idea - a decent solution, or a bit of a bodge?
Jek
40inches
posted on 15/12/11 at 01:24 PM Reply With Quote
Your example is for anti vibration, not misalignment. I used a Truflex section ( 2.25' 57mm TRUFLEX STAINLESS FLEXIBLE EXHAUST PIPE BEND | eBay), saved a lot of time and head scratching, not cheap though.
[Edited on 15-12-11 by 40inches]
JekRankin
posted on 15/12/11 at 01:52 PM Reply With Quote
Interesting, thanks for the link. Looks a little long for my application but will have a look for a smaller version. Failing that, seems like they sell suitable pre-bent lengths of stainless tube if I decide to go down the welding route.
Jek
40inches
posted on 15/12/11 at 01:54 PM Reply With Quote
Jek
They make them up themselves, ask them to make one to your size
posted on 15/12/11 at 04:45 PM Reply With Quote
Just beware that flexi joints are not designed to support the weight of an exhaust in the way a solid tube could. Typically a tin top will have an exhaust hanger near a flexi joint.
