Author: Subject: Still got pinto starting issues - compression question
theduck
posted on 19/12/11 at 08:17 PM Reply With Quote
So she still won't start, so tonight conducted a crude timing test and was getting compression on cylinder one approx 90drgrees after tdc according to the timing arrow on the cam pulley. My crude engine knowledge tells me this is wrong?
posted on 19/12/11 at 08:28 PM Reply With Quote
No it is right on 4 cylinder 4 stroke you should get compression every 90 degrees of cam rotation --- ie 2 compressions per crank rotation.
Xtreme Kermit
posted on 19/12/11 at 08:34 PM Reply With Quote
Sounds like its back to first principals. Cam box off, find tdc using the crank markers for number 1 and make sure the valves are closed. Then make sure the rotor arm is pointing to number one plug.
If anything is not lined up, you have a problem...
snapper
posted on 19/12/11 at 08:35 PM Reply With Quote
Set no. 1 piston to TDC measure lift at inlet and exhaust, they should be the same, the next rotation of the crank should have valves closed and distributor arm pointing to no 1 spark plug
I eat to survive
I drink to forget
theduck
posted on 19/12/11 at 09:13 PM Reply With Quote
Thanks all. With all your help I will get this engine started!
Unless it's f***ed
