Author: Subject: HELP? Cheap tube and bends for exhaust making ZZR1100
jossey
posted on 20/12/11 at 12:00 PM Reply With Quote
can anyone point me in the right direction for getting my exhaust built up.
Thanksssss
David Johnson
djtom
posted on 20/12/11 at 12:27 PM Reply With Quote
I've got a big box of stainless bends in 3" tubing going cheap. They are hydraulic bent not mandrel bent so there are forming ridges on the inside of the bend, so there will be a bit of airflow disruption, but at the end of the day it's a 3" pipe, so it won't make much difference!
They will be very cheap if you are interested. I was after somewhere in the region of £60 for the whole box and there must be 15-20 bends in there, most with long tails on the bends too. Bends vary from 10 deg to 90 deg.
Let me know if you are interested and I'll dig them out and take some photos.
Regards,
Tom
jossey
posted on 20/12/11 at 12:36 PM Reply With Quote
3" Is a bit big me thinks but im asking a biker the best size. Thanks though.....
David Johnson
minitici
posted on 20/12/11 at 01:06 PM Reply With Quote
Buy a couple of cheap secondhand, stainless steel bike exhaust down pipes/headers from e-bay and cut and weld these to suit.
Jimbob
posted on 20/12/11 at 01:12 PM Reply With Quote
http://www.kitspares.co.uk/shop/catagory.php?cat=7&catsub=1
twybrow
posted on 20/12/11 at 01:23 PM Reply With Quote
I have a set of Zx12 headers from the bike in my shed - perfect for cutting and shutting to make a custom set of headers.... Open to offers!
jossey
posted on 20/12/11 at 01:54 PM Reply With Quote
are they stainless steel please sir?
David Johnson
Confused but excited.
posted on 20/12/11 at 05:55 PM Reply With Quote
Jossey, what diameter do you need? I have some stainless bends; 2", 90deg, 1.6mm wall, mandrel bent, that are surplus to requirements. Not as cheap as those 38mm in Jimbob's link though.
NS Dev
posted on 23/12/11 at 02:52 PM Reply With Quote
Buy stainless steel hygienic or "dairy" bends. You are looking at around a fiver each for 2" ones in 316L grade, they are mandrel formed and polished inside and out.
Damstahl in telford are a helpful stockist
posted on 23/12/11 at 05:25 PM Reply With Quote
Poo!
Wish you'd posted that before I bought mine.
Uphill Racer
posted on 28/12/11 at 12:31 AM Reply With Quote
I cut and altered the standard pipes, gas welded and ground the insides where necessary. After the collectors I used 2" IIRC.
