Author: Subject: throttle probs
butski99
posted on 3/1/12 at 03:29 PM Reply With Quote
throttle probs
hi there,
i am having trouble with my throttle, i have a nissan micra k11 1.3 engine in my classic mini
but the pedal travel is too much, i have to lift my foot right up and littaraly press down on it
is there an easy way to shorten pedal travel but keep full travel at the other end
all idea's very welcome
thanks
lee
blakep82
posted on 3/1/12 at 03:45 PM Reply With Quote
you can move the ratio between the pivot and where the cable attaches... move the cable further from the pivot on the pedal, and you'll have to move the pedal less distance to open the carb/throttle body to wide open
________________________
butski99
posted on 3/1/12 at 03:55 PM Reply With Quote
doh !!!
thanks, i knew there would be a simple solution, just had a complete brain block
