Author: Subject: Few Zetec questions
JeffJeffers
posted on 10/1/12 at 10:52 PM Reply With Quote
Few Zetec questions
I finally got all my coolant pipes plumbed in tonight so I could run the engine properly.
I didn't have it running for many minutes and the exhaust manifold started glowing red. Is this normal?
Also the engine seems to be idling at about 2,000 rpm. I have the standard injection system and ECU. What I have noticed is if I unplug the idle control valve it makes no difference to the idle. Is this normal or does it sound like the valve isn't working properly?
austin man
posted on 10/1/12 at 11:20 PM Reply With Quote
glowing red not a good sign really my 1.8 doesnt glow red even when thrashed its on carbs not injected sound like its running lean to me
eddie99
posted on 10/1/12 at 11:23 PM Reply With Quote
As above, doesnt sound good.... Too hot so too lean... I've never had mine noticeably glowing anything like red.
matt_gsxr
posted on 10/1/12 at 11:33 PM Reply With Quote
if not lean then perhaps your timing is retarded then you can put heat into exhaust that way, worth checking the timing if you have adjusted it.
Dusty
posted on 10/1/12 at 11:57 PM Reply With Quote
Fast idle suggests inlet air leak, red hot exhaust suggests running lean. Unplugging idle air control valve has no effect. Sherlock might deduce the IAC valve is wide open fitting all the known facts of the case very neatly.
Of course sods law means it will be the throgmingle cordwangler which turns out to be faulty but the clues did fit neatly together!
big_wasa
posted on 11/1/12 at 06:53 AM Reply With Quote
you have an air leak mate.
It should stall dead with out the idle valve working. If the idle valve is making a funny farting noise then it is the wrong way around ?
you want a tin of easy start or somthing and check around the mani for leaks.
If you want a hand give me a shout.
JeffJeffers
posted on 11/1/12 at 10:07 AM Reply With Quote
A tin of easy start it is then. Thanks all.
I may take you up on your offer big-wasa. Have you got your IVA booked yet?
loggyboy
posted on 11/1/12 at 10:34 AM Reply With Quote
I WANT to know where I can get me one of these!
Alfa145
posted on 11/1/12 at 12:03 PM Reply With Quote
In the LocostBuilders forum Shop of course!
r1_pete
posted on 11/1/12 at 01:12 PM Reply With Quote
It'll get you into trouble ---- Link
JeffJeffers
posted on 19/1/12 at 03:54 PM Reply With Quote
Turns out it wasn't the throgmingle cordwangler.
I tested the inlet system with a tin of easy start but I couldn't find any signs of an air leak.
After a bit of messing around I found the fault was the idle control valve, or to be more honest the way I fitted the idle control valve.
I had fitted the idle valve the wrong way round. It turns out it doesn't close when fitted wrong.
