webbey
posted on 10/1/12 at 11:05 PM |
Zetec 2L water block - where do these go???
Hi There
i am trying to plumb the header tank in and pipe work and i am a bit unsure where everything goes, can somone please steer me in the right
direction, the photo below shows my water block can you tell me where the pipes go
[img][/img]
pipe 1 =
pipe 2 =
pipe 3 =
pipe 4 =
also does the header tank need to sit above the water block?
bigdrew
posted on 10/1/12 at 11:42 PM |
Pipe 1 is to top of header tank
pipe 2 is to top of rad
Pipe 3 wants to be t pieced in to the hose comming of the bottom of the rad
pipe 4 is the heater and this can be blocked off.
Where pipe 1 enters the header tank should be the highest point in the system
bigdrew
posted on 10/1/12 at 11:43 PM |
http://www.locostbuilders.co.uk/viewthread.php?tid=159898
Scroll down on that link for a diagram..
Dusty
posted on 10/1/12 at 11:47 PM |
If you are going to have a heater then you can run 4 through the heater and down to the bottom hose with a T piece and block off 3. Either 3 or 4 but
not both needs to act as a warm-up bypass with the other blocked off. 3 is the proper by-pass, is controlled by the thermostat and closes when the
engine is hot. 4 will act as a warm-up bypass and with the restriction of flow the heater gives will avoid overcooling, even though it is
'open' all the time. I have used this method with heater for 5 years with no problems.
[Edited on 11/1/12 by Dusty]
Norfolkluegojnr
posted on 11/1/12 at 08:36 AM |
This is how mine is plumbed in, works fine:
think this was a diagram from another locoster?
Paul Turner
posted on 11/1/12 at 08:46 AM |
See my colour diagram hosted by Lewis Parrrrp!!! about 1/2 way down, its worked perfectly now for 10 years on both a Silvertop and now Blacktop.
http://www.locostbuilders.co.uk/forum/9/viewthread.php?tid=161780
webbey
posted on 11/1/12 at 02:39 PM |
Cheers for all your help
webbey
posted on 21/1/12 at 12:07 AM |
Hi again, I was thinking has anyone tried putting the larger expansion bottle pipe to the heater port (on my photo as position 4)??
