Author: Subject: will a 1.4/1.6CVH sump fit a 1.8CVH?
Bluemoon
posted on 16/1/12 at 02:49 PM Reply With Quote
I all looking to get a new 1.8 CVH sump (to chop) and having difficulty getting one, any one know if a 1.4/1.6CVH Engine Oil Sump will fit (these are readly avaliable via e-bay for about £32 new...)..
Dan
Norfolkluegojnr
posted on 16/1/12 at 03:00 PM Reply With Quote
I assume you mean to fit to a Zetec bottom end?
Don't think so, hence the rarity and desirability of the 1.8.
whitestu
posted on 16/1/12 at 03:01 PM Reply With Quote
I think the 1.8 sumps are different, but only because I've heard of 1.8 sumps being used for Zetecs as they are easy to chop, but I have never heard of anyone doing this with a 1.6 sump.
Stu
loggyboy
posted on 16/1/12 at 03:04 PM Reply With Quote
Isnt it because the 1.8 CVH is rear drive where as all the lower CVH engines are from FWD car?
Bluemoon
posted on 16/1/12 at 03:05 PM Reply With Quote
Not seen any one try
No to fit the 1.8CVH.... Don't care about baffle plates etc as will modify for shortened pick-up.. I suspect it may fit but then again maybe something major is different with the bottom of the block on a 1.8 engine...
Dan
Bluemoon
posted on 16/1/12 at 03:11 PM Reply With Quote
Yes but can't see that being a problem for me as no cross member ect to clear and modifying sump any how???
Bluemoon
posted on 16/1/12 at 03:18 PM Reply With Quote
" target="_blank">http://4.bp.blogspot.com/_RivBmYlKyss /SlxXAtintrI/AAAAAAAAA9g/bQg_t46IJrM/s1600-h/engine_cvh.jpg
O.k above is from a none 1.8CVH looks like the pickup is at the front so the bump is at the "wrong" end??? Not a show stopper with a sump chop...
[Edited on 16/1/12 by Bluemoon]
whitestu
posted on 16/1/12 at 03:50 PM Reply With Quote
I wonder if a 2 part sump from a Blacktop Zetec would fit? The lower part is easy to shorten.
Stu
