scotty g
posted on 19/1/12 at 07:22 PM |
alternator on your Zetec.
Just a quickie guys, what Alternator are you running with your Zetec's, is there a prefered option to look out for?
Cheers.
big_wasa
posted on 19/1/12 at 08:09 PM |
You can use just about anything thats 12v and you can fit in the hole.
Ive used all sorts but the two most used are the Denso (Diahatsu four track) and the Lucas (80's fords).
lotusmadandy
I use a small denso unit from a nissan micra.
do an ebay search for denso alternator,you
should find a small unit on there.
Paul Turner
posted on 19/1/12 at 08:50 PM |
Have used Lucas, Motorola and now use an ancient Denso off an 80's Charade GTTi, bloke up the street gave it me, brilliant, worth every penny.
lsdweb
posted on 19/1/12 at 09:36 PM |
Denso on mine a few years ago.
Alternator & Crank Sensor
austin man
posted on 19/1/12 at 09:53 PM |
using the standard pinto on mine, I have bike cars so it gives more clearance than the plenum some use with injection
whitestu
posted on 19/1/12 at 09:55 PM |
A little Denso one on mine as well.
Stu
James
posted on 20/1/12 at 12:32 AM |
Vauxhall (Bedford?) Rascal one on my Pinto.
- Muhammad Ali
