lewis
posted on 21/1/12 at 11:57 AM |
Zetec water temp sender
I need one of these as I forgot to remove it from my pinto before flogging it :-(
http://www.merlinmotorsport.co.uk/p1374/TELEMETRIX-WATER-TEMPERATURE-SENDER-1/8NPT/product_info.html
My question is where do I fit it to my zetec black top?
Is there one fitted to the zetec already? (I'm using original thermostat) that I could use??
Cheers Lewis.
I am a driving god!..........sort of
posted on 21/1/12 at 12:02 PM |
On my thermostat housing there is a 1/8npt under the housing below the bypass outlet. On some its threaded and others are blanked off, not sure which
ones though.
lewis
posted on 21/1/12 at 12:05 PM |
Thanks coozer,is that where the original ford temp sender goes/is?
macc man
posted on 21/1/12 at 12:06 PM |
Should be one already fitted in the thermostat housing. It is hard to see as it is underneath. If required you can change it for a different one if
the thread is the same. Remember it will need an earth as the body is plastic.
RichardK
posted on 21/1/12 at 12:09 PM |
My blacktop thermo housing was blocked off at the bottom,got one off a silver top as the have the npt one underneath.
Just a side note go nice and easy on torx bolts at the bottom of the housing as the housing can leak when the o ring perishes between the housing and
head and cause the torx bolts to corrode.got mine out just going back and forth tiny amount,about 45 mins! But came out in one piece ,would be a
nightmare if they snapped.
Head to Housing Seal 1135946 £1.24 1 needed
o-Ring for thermostat 1092262 £1.23 1 needed
Torx Screw 1097036 £0.73 3 needed
Front Housing 1109329 £17.34 1 needed
Just thought you may need the part number of the o ring if you're taking the thermo housing off to swap. This what I needed you may only need
the first part.
Rich
[Edited on 21/1/12 by RichardK]
Gallery updated 11/01/2011
posted on 21/1/12 at 12:13 PM |
One on top is for the ECu, one for the dash meter is somewhere else near the rad in the pipework I think, it aint on the engine.
lewis
posted on 21/1/12 at 12:17 PM |
Ok thanks,I have a phase 3 engine do don't surpose there is a hole on mine :-( ill take a look.
RichardK
posted on 21/1/12 at 12:26 PM |
This thread shows where it is although it's upside down!
http://www.locostbuilders.co.uk/viewthread.php?tid=125495
Rich
lewis
posted on 21/1/12 at 12:29 PM |
Thanks rich just need to check if I have one. But don't think I do so might have to go down the route below
https://www.merlinmotorsport.co.uk/checkout/?products_id=1374/TELEMETRIX-WATER-TEMPERATURE-SENDER-1
RichardK
posted on 21/1/12 at 12:32 PM |
That link doesn't work,think its looking for items in your basket,however if your thinking about using the top one it will work but you wont
have any warm up temp,it'll only when the thermo stat opens that you'll start the get a display,this may not bother you,just thought
I'd mention it if that's what you're planning.
