Author: Subject: Injector Blanks
AntonUK
posted on 22/1/12 at 04:11 PM Reply With Quote
Injector Blanks
I'm in the process of putting together my GSXR TB's on a ST170 manifold. Obviously I need to blank off one of the sets of injector holes. I know the norm is chemical metal, but I would like a removable solution in case I ever decide to got to staged injection or wish to change the injector location (testing on a RR for example).
Is there an off the shelf "injector blank' that is available or do I need to have something knocked up on a lathe?
wombat
posted on 22/1/12 at 04:21 PM Reply With Quote
Blanks
I have a spare set for GSXR 600s if interested....
posted on 22/1/12 at 04:23 PM Reply With Quote
Drop Flakmonkey a U2U... I'm sure he could sort you out!
It's Evolution Baby!
davidimurray
posted on 22/1/12 at 04:24 PM Reply With Quote
Never use chemical metal. I learnt the hard way when the slug was sucked out of the throttle bodies and into the engine, resulting in bent valves
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
AntonUK
posted on 22/1/12 at 04:29 PM Reply With Quote
Wow quick response thanks
Wombat you have U2U
wombat
posted on 22/1/12 at 04:39 PM Reply With Quote
u2u back.
Have a look at my pictures to see what they look like....
dave r
posted on 22/1/12 at 05:14 PM Reply With Quote
apparently raceline do the blanks.......
i couldnt find them when i was looking for them
mine are quite a close hole size for a bsp thread, so i tapped mine up and pu bungs in
no good if you want to re-use them though
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
pjay
posted on 22/1/12 at 08:57 PM Reply With Quote
Not a problem if the slug is shaped so that it can't be sucked in. I filled mine to the lip on the injector ports - on the GSXR1000s this gave a shaped slug.
Jenko
posted on 23/1/12 at 10:11 AM Reply With Quote
Totally agree - Chemical metal works a treat, but as long as you form is around the shape of the entire injector port. So a cross section would look 'T' Shaped.
I would not worry about re using the ports...if you go for an 8 injector, then you would have the GSXR injectors in the current position, and a set pointing down the trumpets.
MY BLOG - http://westfieldv8.blogspot.co.uk/
