Author: Subject: fireblade fuel pump
loughlin1
posted on 23/1/12 at 11:10 AM Reply With Quote
fireblade fuel pump
Hi All
Would someone have any pictures of the motorbike fuel pump fitted on their car as i am in a quandry as to fit it vertical or horizontal on the car any advice would be great
Dangle_kt
posted on 23/1/12 at 11:24 AM Reply With Quote
I fitted mine horizontally, onto one of the chassis rails for the rubber carrier.
loughlin1
posted on 23/1/12 at 11:25 AM Reply With Quote
great many thanks that is all i needed to know thanks again
Andy B
posted on 23/1/12 at 12:44 PM Reply With Quote
make sure that when you mount it the small vent on the plastic end cap is pointing down, this is a condensation drain and if mounted upowards the moisture will collect and short out the motor contacts
best regards
loughlin1
posted on 23/1/12 at 05:06 PM Reply With Quote
GOOD ADVICE MANY THANKS i would not have known
