Nitrogeno25
| posted on 23/1/12 at 08:48 PM |
engine mounts, can't decide
Lots of questions here! I'm replacing a Fiat TC engine that were far back in my chassis with the Duratec. Unlike others I have to move the
engine to the front, but engine mount are a little off:
Will it work OK with this slant? (The mounting rubber is Land Rover 50mm diameter). I read Flak monkey's thread but mine is the other way,
forward instead of backwards...
Many thanks!
Tatey
| posted on 23/1/12 at 09:22 PM |
I'd say it will be fine. The duratec is a light weight engine and the landrover mounts are very ridgid. Just use some large box if you want to
be on the safe side.
clairetoo
| posted on 23/1/12 at 09:41 PM |
That should be fine - my left mount comes back at more of an angle than that , and the right one angles forward ..........
Its cuz I is blond , innit
Claire xx
Will weld for food......
loggyboy
| posted on 23/1/12 at 09:47 PM |
Can you not extend the plate to the left (there seems to be a useable bolt hole to the left and up a bit) and then angle the mount slightly less, so
it comes between the to bolts on the left. (if theres enough gap between those bolts.
loggyboy
| posted on 23/1/12 at 11:16 PM |
Or something like this?:
  Duratec Mount
Nitrogeno25
| posted on 24/1/12 at 01:25 AM |
Yes, it can be done on these side, not on the other thought. Thanks!
Nitrogeno25
| posted on 24/1/12 at 01:26 AM |
  Duratec Mount
Actually I was thinking of something like that. Many thanks!
