se7ensport
| posted on 29/1/12 at 09:14 PM |
New repackable silencer leaks
Just fitted a new repackable silencer and it leaks slightly at both ends of the can between the bolts, will this seal after running in?.. if not, what
is the recommended fix?
  Exhaust leak
adithorp
| posted on 29/1/12 at 09:41 PM |
Silicone sealant. Yes, it will stand the temp (clear is best for temp stability). Exhaust sealant can break up and come out so silicone is better.
http://jpsc.org.uk/forum/
se7ensport
| posted on 29/1/12 at 10:06 PM |
Thanks for the tip, guessing taking it apart is the best way to fit the sealant rather than trying to squeeze it in?
adithorp
| posted on 29/1/12 at 10:27 PM |
Usually has better results that way.
fesycresy
| posted on 30/1/12 at 09:17 AM |
If you find your local Plumb Centre, they can supply high temperature silicone sealant.
We use it to seal stainless flues on industrial heaters and boilers.
